Back when it started w/ the mustangs, they put a 351Windsor cam in it. It just changed the firing order. Then they started putting forged pistons & roller cams in them. '92 & up 5.0 trucks have roller cams. Speed density trucks have the old 302 firing order & mass air trucks have the Windsor firing order. But they're not exactly "H.O."
I don't believe the roller cams started in the F-Series/Bronco until the 1994 model year.
The term "HO" has been used on various models and included different components throughout the years. On the F-Series/Broncos in the 1980s it referred to the 351/4 barrel (or "V") vis a vis the 351/2 barrel.
dn.
Reason: additional info
There really is only one 5.0HO and it was only ever put in cars, the cam, intake, pistons, and computer are unique to this motor. The vast majority of all late model('87+) 5.0 motors share the same block, heads, and rotating assembly(with the exception of pistons), but.. in terms of peak output the truck motors actually have more potential because it has the largest volume intake by far. The '87 to '92 HO motors got forged pistons and that is beneficial if power adders are used, but natuarally aspirated make no difference.
The Explorer/Mountaineer motor actually has more HP potential than either the Mustang or truck motor due to the GT40 heads, but it was never considered a HO.. probably because of the RV style cam that was installed.
Bottom line is you're not getting anywhere near full potential form any 5.0 with the stock camshaft, there's lots more power waiting to get out.
so if i have a 91 f150 with the 302 what vehicles/parts would i want to look for to get the most powerful 302 keeping it stock
mustang intake and computer
explorer gt-40 heads
and the roller cam from a 94+ f150 ?
im looking for an extended cab with the 302 to replace my old beater 91 and my boss has a gorgeous 91 w/ 302 ford premium reman engine he is willing to sell to me, for a price LOL
im asking because i basically want the best performance possible but still be able to say its a stock 302 HAHA
Ok. In '94 the 5.0 engine in the truck & the Mustang are essentially the same. They have different intake & exhaust manifolds & possibly a different cam grind (couldn't find much about specs). Of course the totally different ECM controlled fuel & ignition timing curves. According to Ford, though, the Mustang "H.O." engine only produces a few more horsepower than the truck engine. Phenominal.
