302 vs 302 HO
Old Oct 3, 2001 | 08:07 PM
95xltmud's Avatar
95xltmud
302 vs 302 HO
What is the difference between the 302 and the 302 HO. I am bbuilding up my 95 F150 and i am looking in the crane cams catalog for roller rockers and a new cam but the only 302 listed is the HO? Is there a difference?
Old Oct 4, 2001 | 01:48 AM
StangMan's Avatar
StangMan
302 vs 302 HO
As I understand it, the standard 302 is a non-roller engine, meaning mechanical rockers, while the HO is a roller engine, having roller-rockers. Roller-rockers have a bearing at their bottom that allows the rockers to move more freely, without the dragging of the mechanical rockers.
Hope this helps.
Old Oct 4, 2001 | 10:07 AM
markus's Avatar
markus
302 vs 302 HO
The Firing Order is different as well. The 302 HO has the same firing order as a 351W. I don't remember it offhand.
Old Oct 4, 2001 | 07:15 PM
15sec79's Avatar
15sec79
302 vs 302 HO
HO motors 1986 through 93 had forged pistons and 9.0 - 1 compression, roller lifters (NOT rockers), a bigger cam with 351w firing order, and were rated from 215 to 225 horsepower. All had better flowing upper intakes and bigger throttle bodies.
most all 302's (HO or not) had roller lifters. Non HO's had cast pistons with deeper dishes and lower compression, worse flowing heads, and were rated from about 160 to 190 horsepower.
15 second 1979 f-100 - 302, 3.70's, Powertrax Locker, MSD box, 2300 stall, headers, 4bbl. SOON to be 14 second 79.
I would rather PUSH a Ford than drive a Chevy!
Old Oct 4, 2001 | 08:51 PM
Franklin2's Avatar
Franklin2
302 vs 302 HO
15sec79 is correct. I have a 86 non-HO 302 out of a markvii and it has roller lifters, but has the normal 302 firing order. It also has a one piece rear main seal.
Old Oct 6, 2001 | 10:13 PM
bigdad4u2hug's Avatar
bigdad4u2hug
302 vs 302 HO
Old Aug 26, 2022 | 08:41 PM
humbert1961's Avatar
humbert1961
1st Gear
302 H, O
How to upgrade a 302 H, O ?
Old Aug 27, 2022 | 12:25 PM
xlt4wd90's Avatar
xlt4wd90
What are you wanting to do?
Old Sep 9, 2022 | 01:00 PM
bwguardian's Avatar
bwguardian
To clear up some things. The HO has the same firing order as the 351...and that's the only difference. The 5.0 HO was carb'd with flat top cast pistons that had four valve reliefs from 82-84.5 with 82 having a 2 barrel and all others having a 4 barrel. So 85 was a carb'd 4 barrel, but it got forged flat top pistons...same previous piston top...and a roller camshaft. In 86 it got fuel injection with true flat top pistons...no valve reliefs. In 87 the piston tops came back with the four valve reliefs, but also got a center dish worth about 4cc, but were still forged slugs. Somewhere in the early 90's the pistons went from forged to hypereutectic slugs...
Krisverde
Aug 19, 2015 01:06 AM
hotrodder72
13
Mar 5, 2010 04:55 PM
Jrock909
Mar 18, 2007 07:19 AM
NeXtras
Feb 17, 2007 12:16 PM
chris_567
Apr 10, 2005 10:54 PM
