Pvc Valve
Old Oct 29, 2009 | 01:03 PM
ImmortalDesign's Avatar
ImmortalDesign
Pvc Valve
Ok if somebody could help I have connected about a quarter of the vacuume system in my 83 f150 4.9l. Though I have found a diagram i can use I'm not sure where te pvc valve hooks up to.
Thank you for your time.
Old Oct 29, 2009 | 02:27 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
It's one of the large (3/4 if I remember rightly) vacuum ports just below the carb in either the carb spacer or intake manifold.
One is for the brake booster and the other is for the PCV valve.
Be advised that you may have a vacuum tree comming off the intake at one of these ports.
The large PCV valve port hooks into the one closest to the carb throttle body.
Also be advised that your truck may have a canister purge system. The small port of the PCV valve will hook to that system.
abyars111
Oct 31, 2014 04:10 PM
Milwaukee1979F150
Modular V10 (6.8l)
Sep 14, 2009 05:32 AM
anah go karts
1997 - 2003 F150
Mar 28, 2009 11:58 PM
kennedyford
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 13, 2006 11:48 AM
Rob88
Mar 8, 2000 10:22 PM
