PVC Valve
Old Mar 8, 2000 | 01:37 PM
Rob88's Avatar
Rob88
PVC Valve
Does a 1988 302V8 have a PVC valve? My f150 doesn't appear to have one?
Thanks
Rob
Old Mar 8, 2000 | 02:11 PM
slikness's Avatar
slikness
PVC Valve
I think they've been using PCVs since the late 60s. Although there were some that did not use the PCV and vented the crankcase fumes directly into the air. Yours should have a PCV from what I read.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Mar 8, 2000 | 05:54 PM
Pastmaster's Avatar
Pastmaster
PVC Valve
My buddy's 88 F-250 with the 351W/c-6 didn't have one. You might check under the upperintake manifold on the passenger side, has a hose going into it
Old Mar 8, 2000 | 06:19 PM
slik's Avatar
slik
PVC Valve
Yeah, it could have to do with the trucks and heavy duty gvw, etc. But, if you don't have one, you should put one in. You should see a slight improvement in gas mileage.
Slik
Old Mar 8, 2000 | 09:11 PM
GSchretter's Avatar
GSchretter
PVC Valve
If you truck is like mine:
87 F-150 - 302..
It is under where the intake curves over the
left valve cover in the far back.
Old Mar 8, 2000 | 10:22 PM
PAUL_2's Avatar
PAUL_2
PVC Valve
abyars111
Oct 31, 2014 04:10 PM
Albert Sanchez
1983 - 2012 Ranger & B-Series
May 12, 2014 12:49 AM
Twistedtesty
Mar 19, 2013 11:12 AM
Milwaukee1979F150
Modular V10 (6.8l)
Sep 14, 2009 05:32 AM
anah go karts
1997 - 2003 F150
Mar 28, 2009 11:58 PM
