64 f250 cummins swap
Old Sep 16, 2010 | 01:35 PM
  #46
ChaseTruck754's Avatar
ChaseTruck754
Originally Posted by fordman67
I have an 18month old little girl and an understanding wife.They deserve my time and I only have so much garage space !
I need to get this cab up off the floor to make it easier to work on.
I wonder if saw horses would hold this thing?
Getting older and moving on in life definitely slows down the shop time!
I am trying to get some stuff done before I settle down but it's just not happening at this point. Very frustrating, especially when I notice that my "free" time to work on things is getting less and less.
As for the saw horses - they would probably hold the body if they are sturdy ones.
In the past I've made a couple stands for different projects and then I use pipe stands similar to the ones in the pic below as well.
Old Sep 17, 2010 | 10:12 PM
  #47
fordman67's Avatar
fordman67
I was thinking some horses that the upper tube would sit inside the rocker on either side from front to back.Then I could get to the underside of the floor as well.
The mustang is leaving tomorrow! Now I will have two bays to devote to the truck.I will actually be able to have all the body panels out to work on them!
Old Sep 20, 2010 | 05:16 PM
  #48
ChaseTruck754
I've got 2 of the stands like above that I took the upper "Y" portion out of and the sit under the front body mounts like in the pic below. The rear just sits on the tires as the axle, etc. is still in it back there. Works well and I can get to everything.
Old Sep 20, 2010 | 10:42 PM
  #49
fordman67's Avatar
fordman67
nice! Hope to get it back up on at least some jack stands tomorrow night.
Sisters stinking minivan is broken down again and I need to get to it for her.
Mustang not gone yet! The guy buying it is not getting in any hurry.But I did dig the fenders and inner fenders out 2nite.They are in better shape than I remembered.Actually they are VERY nice.
Old Sep 30, 2010 | 12:35 PM
  #50
fordman67's Avatar
fordman67
Well I got the cab up on stands and got the drivers side lower pillar completly cut out to remove all the rust.Also drivers cab corner.I am going to brace what I have done back up and take it to the dipper.I just dont see going any further until it is cleaner.It will be impossible to weld properly.
Old Oct 8, 2010 | 12:14 AM
  #51
fordman67's Avatar
fordman67
Last night after work I got some time to tinker with the radiator support.
I needed as much room as I could get to accomodate the electric fans.
So the nice non rusty new radiator support met the plasma cutter.All the factory radiator mounting is shaved completly off.I would have to say that it made a huge difference.Only one other problem now.The intercooler pipes are needing to run directly through the shocks! Too bad I cant turn the IC over upside down.Next need to build rad and IC mounts.
Still need to get cab taken to the stripper tank.
Old Oct 8, 2010 | 12:47 PM
  #52
ChaseTruck754
That must be a really wide IC - which one are you using?
Old Oct 11, 2010 | 10:15 PM
  #53
fordman67's Avatar
fordman67
I have the radiator and ic from a 97 dodge.YEA it is wide.I am going to have to heavily modify the inner fenders as well.I will snap some pics and post them up.Also got the cab braced up and finished cutting the old rusty cab corners out and got some friends over and got it on the trailer to go get dipped!
Next i will need to figure out trans cooler weather to put in front of ic or to put under the bed with a thermostatic controlled fan on it?(i like the later better)
Old Oct 12, 2010 | 10:24 PM
  #54
fordman67's Avatar
fordman67
Got ic and rad mounts mostly figured out and partially built.Maybe the inner fenders will not need radical reengineering.but work none the less.
Old Oct 12, 2010 | 10:48 PM
  #55
MariosF250's Avatar
MariosF250
Wow this an awesome thread fordman. looking forward to future updates
Old Oct 14, 2010 | 12:38 PM
  #56
fordman67's Avatar
fordman67
Thanks,I will keep em coming,just been busy w being a new dad.I want to get this thing going!
Old Oct 18, 2010 | 11:34 PM
  #57
American Thunder's Avatar
American Thunder
Awesome project! I want to see more pics..
Old Oct 19, 2010 | 07:14 PM
  #58
fordman67's Avatar
fordman67
Will do soon.kinda waiting until I get rad support,rad,IC worked out.
Also was thumbing through summit and found a hayden engine oil cooler w -8 fittings and integral fan that I think will do the trick to cool the big ol allison.It has -8 fittings already from factory.
Waiting on cab to get back from redi strip.
Old Oct 21, 2010 | 09:45 PM
  #59
fordman67's Avatar
fordman67
MAJOR SCORE! I found a dana 61 out of an 84 e350...3.07 ratio
It has been paid for and is on its way! Sure hope I can make it fit!
Old Oct 22, 2010 | 02:23 AM
  #60
ChaseTruck754
Are you considering it a score due to the really tall gear ratio??? I've got a buddy with a d61 rear in his 76 and he's had some pretty good problems finding brake parts (drums and shows mainly) for the thing. All the more reason to swap over to disk if you hadn't planned on it.
