Imitation Harley lights - are they worthwhile?
There's been plenty of threads that show cutting the header panel to fit these. But what I want to know is, over the long haul, are they a good upgrade?
Are they any good? They seem to be 1/3 the cost of the OEM genuine Harley lights.
Do they last? Has anyone found them to craze or go yellow with age?
Is it worth getting a pair of the 'imitation' Harley lights from one of the reputable ebay sellers - for example headlightsdepot for $178.95 pr or headlightswholesale $159.95 pr.
See:
04 2004 FORD F250 F350 SUPER DUTY 07 HARLEY HEADLIGHTS: eBay Motors (item 400149751860 end time Sep-30-10 22:42:02 PDT)
and
99 1999 FORD F250 F350 SUPERDUTY 2007 HARLEY HEADLIGHTS: eBay Motors (item 380267702349 end time Sep-20-10 02:59:44 PDT)
Are these the same imitation product?
Is this a case of you get what you pay for - so the genuine OEMs are really worth the money and are the way to go?
See:
and
IMO, the OEM are much better quality in the long run and really aren't that much more. I have sold several sets to customers who first used the gypo aftermarket lights and they have had issues with water leakage, fogging, and hazing of the lenses.
See:
See:
iv had them from that seller for a few months and they are great no water or fading problems yet.
If you are up for a bit of 'splice and dice' with the wiring, anything is possible.
I'm going to use the stock plug to run relays for the high and low beam of the new lights.
In fact, I planning to make 2 twin-relay harnesses and run each of the new headlights with a harness between the stock plug triggering relays connected to the battery (via fusible link) directly behind each of the headlights. The wire powering the headlight will be very short and very thick which will maximize the voltage getting to the bulb.
I've decided to give the 'headlights depot' 'gypo' set a go. I'll open them and carefully seal them with clear silicone sealant before I fit them.
Ideally I'd like to get the OEM set (a problem avoided is a problem solved), but I've just spent a bucket of cash on a pile of other spares, repairs and a few new tools.
I've just received the imitation Harley lights. They look good but in transit something got broken. A small plastic clip has fallen out and the reflector unit is moving about inside the light.
Has anyone opened one of these lights?
Is it just a matter of unlatching the tabs and prizing off the clear lens?
I'm sure it's an easy fix if I can get inside, but I don't want to risk breaking something that has taken a month to arrive!
Got the Harley headlights. Opened the first one, resealed it, and now got it fitted. Tried for about 2 hours to get the second headlight's lens off, same as I'd done for the 1st.
It is sealed so good the actual headlight case is cracking up before the lens has even budged! I don't think there is ever going to be a leakage issue!
Will post pics once completed.
