Pulled Codes - Now what?
Old Oct 31, 2009 | 12:42 PM
Conanski's Avatar
Conanski
Something I have seen is that just because the spout plug is present doesn't necessarally mean it's doing the job and completeing the circuit, if one of the tabs is broken it won't make contact, so pull it out and measure it with a DMM, it should be a direct short or 0 ohms. If it measures anything else replace it.
Old Oct 31, 2009 | 08:04 PM
Chevy 6.2D's Avatar
Chevy 6.2D
Conanski, I will check out the spout plug tomorrow.
Also, shouldn't I have vacuum to the EGR with the engine warmed up and idling? I pulled the line off and there is none. All other vac lines are hooked up and EGR solenoid is plugged in.
Old Nov 1, 2009 | 05:20 AM
subford's Avatar
subford
No you should not. You only have vacuum at mid throttle with a warm engine. No vacuum at idle or WOT.
Old Nov 1, 2009 | 10:53 PM
Chevy 6.2D's Avatar
Chevy 6.2D
Ok, I couldn't remember.
This thing is on the back burner again- maybe tuesday I'll have time to check it out. Had something come up today and for tomorrow night.
Old Nov 14, 2009 | 09:50 AM
Chevy 6.2D's Avatar
Chevy 6.2D
I checked out the wiring for spout and coil. It all seems fine.
I also played with the timing and got shocked when I bumped into one of the spark plug wires, must be time for new wires.
The truck also has a new condition- idling or cruising at steady throttle it will start to miss and if I give it more throttle it clears up and runs fine.
I pulled codes and got the same as I did the first time.
jbharden
Mar 11, 2016 09:10 AM
tmill28
Jan 8, 2016 08:49 PM
Paul52097
Oct 20, 2013 11:37 AM
dragonsfyre
Jul 20, 2013 02:39 AM
geborenzuschaukeln
Apr 8, 2005 10:54 AM
