Rear wiper adjustment ?
Old Oct 27, 2009 | 07:24 AM
CobraGT40's Avatar
CobraGT40
Is there a way to adjust the rear wiper on a '98 Explorer ? It moves too far to the right and not far enough on the left...its pretty noisy and I'm sure its not good for the motor.
Thanks !
Scott
Old Oct 27, 2009 | 10:05 AM
scucci's Avatar
scucci
Remove rear pivot arm.
Lift the pivot arm nut cover.
Remove the nut.
Remove the pivot arm.
Turn the rear wiper switch on and allow the motor to operate for at least one cycle.
Turn the rear wiper switch OFF.
Position the wiper blade outside the wiper arm stop small tab on arm protrusion rests on top of the bracket.
Install the wiper pivot arm onto the wiper motor.
Tighten retaining nut. 113-154 lb/in
Connect the washer hose
Cycle the wiper motor one time to allow the wiper arm to park on the wiper arm stop.
Old Oct 27, 2009 | 03:42 PM
CobraGT40's Avatar
CobraGT40
Remove the nut.
Thanks for the detailed instructions ! That worked perfect, only took about 5 minutes...
Thanks again !
Scott
Old Oct 27, 2009 | 03:59 PM
scucci's Avatar
scucci
Thanks again !
Scott
You're welcome, glad that helped.
Scucci
rocket_scientist
Dec 25, 2016 03:25 PM
hurst1979olds
Nov 20, 2016 11:27 AM
asavage
Aerostar
Oct 6, 2015 01:46 AM
alloro
13
Sep 2, 2015 12:53 PM
Josh S
1983 - 2012 Ranger & B-Series
Aug 25, 2015 06:28 AM
