A wiper problem has me stumped
Old Aug 17, 2015 | 05:49 AM
Josh S's Avatar
Josh S
1988 Bronco II 2.9L
Issues:
- When I turn off the wiper switch the wipers immediately stop in place, they do not continue to their normal 'down' position.
- The switch's adjuster to slow the wipers isn't working, only the low and high settings work.
What I've done so far:
- Replaced wiper switch with used from spare parts.
- Replaced wiper switch with new from spare parts.
- Replaced wiper motor with remanufactured from Autozone.
- Thoroughly cleaned wiper motor ground terminals.
- Replaced interval wiper governor with used from spare parts.
The problem occurred after the truck sat in my garage for 6 months while I removed and reinstalled the engine to replace some gaskets & seals.
Any help would be appreciated.
Old Aug 17, 2015 | 12:28 PM
87 XLT's Avatar
87 XLT
If you PM me with your email address i can scan and email the "park circuit test" from the 87 factory manual, should be the same as your 88
BTW i'm having problems with this site on my PC i keep getting some sort of warning & the PC wants to shut down so i'm typing this on my tablet. I wonder if you or anyone else reading this are having problems?
Old Aug 18, 2015 | 05:27 AM
Josh S's Avatar
Josh S
My PC's both seem to be working with FTE.
Good insight to try a park test. I did and the wipers do not park but instead run continuously which seems to indicate a bad wiper motor. Also there's continuity between the red and black wires and shouldn't be (my 94's working wiper motor has no continuity there). I'll switch it out tonight and post back if it doesn't fix the problem. Otherwise thanks for the help.
Old Aug 19, 2015 | 12:39 AM
87 XLT's Avatar
87 XLT
Yeah, it does sound like a bad wiper motor, strange the reman motor did'nt fix it.
Good luck with it & i guess i need to get my PC looked at.
Old Aug 19, 2015 | 12:57 AM
KF4EYR's Avatar
KF4EYR
on my 1999 ranger it was doing the same thing turned out to be relay in box under hood on drivers side,,, dont know where it is on 1988....
Old Aug 25, 2015 | 06:08 AM
tomw's Avatar
tomw
One thing to note is that the 'intermittent' feature uses the 'park' mechanism and wiring to give the wipers the 'sweep' after it provides power to get the wiper motor off 'park' position. If the wipers won't park by them self, there's a problem internal to the wiper gearbox/electrics. The circuit is sort of 'keep power to the motor until it gets the wiper drive arm to THIS spot, then break power'. Imagine a circle of copper, with a break somewhere around the diameter. It will power all the way around until it gets to the break, then stop. If you 'jumper' the motor to get it off the break in the circle, it will get power from the circle until it gets to the break again. That, more or less, is how the park and intermittent functions work. Lesson over..
tom
Old Aug 25, 2015 | 06:28 AM
Josh S's Avatar
Josh S
Thanks Tom, that helps my understanding. It is fixed now and ended up of all things being the connector between the wiper motor and harness. The wires as they connected to it were badly corroded. I wish I had checked that first instead of taking the whole system apart, including part of the dash, but as always I understand the system much better having done all that.
phoneman91
64
Feb 2, 2025 05:40 PM
truck157
1997 - 2003 F150
Jul 20, 2021 08:08 AM
Grizzly4x4
Oct 21, 2014 02:57 PM
3BadBirds
Apr 17, 2007 08:52 AM
jimbob237
Feb 27, 2006 11:06 PM
