Cruise Control Light...
Old Oct 27, 2009 | 03:51 PM
CobraGT40's Avatar
CobraGT40
Question Cruise Control Light...
Hi all
I was wondering if there is a way to replace the light inside the steering wheel cruise control buttons ? I have a '98 Explorer Sport and the lights work on the right side of the steering wheel, but not the left side. Is this an easy/inexpensive fix...if even possible ?
Thanks !
Scott
Old Oct 27, 2009 | 04:05 PM
scucci's Avatar
scucci
cruise control lamp
E5RY*13466*BA , its from a ford contour,
and fits perfectly, the bulb is slightly longer
but in no way hinders operation.
Disconnect battery. wait 5 minutes.
Remove two bolts holding steering wheel air bag. Set aside air bag.
Remove screws holding cruise switches. Carefully pry the rubber cover from the switch and replace bulbs. Reinstall in reverse order. Takes longer to to write the steps than it does to replace the bulbs. At least for me.
Ford says to replace switch and harness assy for $65.00
Old Oct 27, 2009 | 04:59 PM
CobraGT40's Avatar
CobraGT40
Originally Posted by scucci
cruise control lamp
Thanks for the info...sounds pretty easy. Whereabouts should I look for the bulb ? Is that something I can pick up at Napa, or do I have to go to the Dealership ?
Thanks you again for your help...this little truck needs a lot of nickel-dime work so I'm sure to have plenty more questions !
Thanks !
Scott
Old Oct 27, 2009 | 05:30 PM
scucci's Avatar
scucci
It's a Ford dealer part. If you pull the old one first you may find it at napa.
The Stage
1997 - 2003 F150
Mar 7, 2019 09:21 PM
bumblebee902
Escape & Escape Hybrid
May 13, 2013 10:22 AM
Pyancey
Jul 25, 2012 12:31 AM
v8swin
1983 - 2012 Ranger & B-Series
Jun 22, 2011 09:16 AM
terestron
Oct 28, 2003 08:40 PM
