Injector software update?
Old Oct 26, 2009 | 08:48 AM
Trakk's Avatar
Trakk
I apparently had a bunch of crud in my fuel bowl that made it into my injectors. The shop I took it to replaced 2 stuck injectors. After doing that and checking things out, they said there's an injector that is not at 100%. They said I may want to have the latest injector software update ( I guess that's a reflash?) Said it may bring that injector back up to 100%. They can't do the software update, but recommended I go to a Ford dealer to have it done.
Does this sound legit? THANKS
Old Oct 26, 2009 | 08:56 AM
Izzy351's Avatar
Izzy351
Tuning won't fix a dodgy injector. What year is your truck and what PCM code is it?
Old Oct 26, 2009 | 09:03 AM
Trakk's Avatar
Trakk
Thanks Joe. '99 model and don't know what PCM code.
Old Oct 26, 2009 | 09:16 AM
Izzy351's Avatar
Izzy351
Early or late 99?
Old Oct 26, 2009 | 09:20 AM
Pocket's Avatar
Pocket
Your shop was probably thinking about the 6.0L trucks. 6.0L's had flash updates for programming to solve some injector issues, and other problems.
The 7.3L's don't have updates for injectors tuning.
Old Oct 26, 2009 | 09:58 AM
Trakk's Avatar
Trakk
thanks pocket. Joe, it's mfd. date: 8/98.
Old Oct 26, 2009 | 10:02 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
No such flash update for the 7.3l. That's for the 6.0l's. Its called a FICM flash update. 7.3's do not have a FICM.
Regardless what engine it is, if the injectors are bad their bad and need to be replaced.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Oct 26, 2009 | 11:29 AM
Pocket's Avatar
Pocket
That makes it an early 99
Old Oct 26, 2009 | 11:35 AM
Izzy351's Avatar
Izzy351
Yep -- that's why I was asking...
You need to find an AB code injector. Late 99 & up have AD injectors.
Old Nov 5, 2009 | 09:07 AM
Trakk's Avatar
Trakk
what's a good source for buying injectors? should I be able to do better than $354? Thanks!
Old Nov 5, 2009 | 09:25 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Yes, you should be able to find a better deal. Give me a call if you need and we can get you fixed up, no problem.
Riffraff Diesel: Alliant Injectors
Old Nov 5, 2009 | 09:33 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Stick with Clay, he has some good pricing on stuff like injectors.
