2000 XLT OEM Fog light question
Can anyone tell me if a 2000 XLT would be pre-wired for the factory fog lights? I would like to install them including the factory switch in the cab, but if I don't have the factory wires, then I will just go without, or go for a separate switch and aftermarket fogs.
Thanks,
Kevin
Thanks,
Kevin
I chose to use OEM fogs but an aftermarket switch mounted to the panel under the steering column. It powers a relay I added on the driver's side under the hood. Ford has provided a set of wires going from under the dash to under the hood making installs like this pretty easy if you choose the aftermarket wiring option.
-Kevin
Adding fogs to my 2000 has been on my To-Do list for awhile now. I just haven't found the time to do it yet.
Do you happen to have the wiring connector/pigtail for the new headlight switch w/fog? This will make things easier. The connectors on the 2000 and newer years with the fog lights are physically the same, but use different pinouts. Pins 2, 5, and 6 are missing on the 2000 connector/harness which can be added but it's much easier to use an existing connector/pigtail that is already wired for fogs.
Pin 12 (BROWN wire) on the 2000 headlight switch connector provides +12V when the headlights are turned on. Tap into this wire and connect to Pin 2 of the connector (Fog Light 12V INPUT). Pin 5 is the Fog Light 12V OUTPUT and this will connect to your relay which will power your fog lights. Pin 6 is for the Fog Light indicator light and connects to ground.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
06-14-2018 10:17 PM
FoundOnRoadDominatin
02-14-2013 08:52 AM
jt371
01-26-2010 08:42 AM
Matt M, PA
11-16-2004 10:30 AM
