Modular V10 (6.8l)
strange noise under acceleration
Old Oct 24, 2009 | 04:19 PM
2000f350v10's Avatar
2000f350v10
on my 2000 F350 V10. when i am accelerating and it hits around 2000-2500 RPMs i heard a noise from the engine that sounds like a bad idler pulley or tensioner. almost a squeal. i replaced the belt, tensioner, and the idler pulley hoping to fix the problem. are the v10s just noisy at times under acceleration? it has 74,000 miles on it. also i do have a couple broken exhaust studs. 2 on the right bank, and 1 on the left. i was thinking maybe i am just hearing the motor through the leaks along with the ticking, but want to make sure.
thanks
2000F350V10
Old Oct 24, 2009 | 06:03 PM
Fordfanatic4life's Avatar
Fordfanatic4life
water pump bearing maybe ???
hard to say without actually hearing ur motor...
Old Oct 26, 2009 | 12:36 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Check the bellhousing cover.
Old Oct 26, 2009 | 03:27 PM
2000silverbullet's Avatar
2000silverbullet
Mine started up again as well. I crawled under with a screwdriver and started tapping around. I found one of the hose clamps (that I installed) holding on the y-pipe cover had disintegrated (love the salt roads!).
I grabbed a pair a vise grips and just ripped it off entirely...
Old Oct 27, 2009 | 09:05 PM
bigjp's Avatar
bigjp
check the dpse sensor hoses just had to replace mine top drivers side towards the back hoses are about 8 to 10 long
jawdoc
Jan 18, 2015 04:24 PM
SleeprLegend
Jul 9, 2010 03:03 PM
87_gt
Apr 9, 2009 09:49 AM
rsav
Dec 12, 2008 04:54 PM
shami02
Jan 17, 2001 12:15 AM
