Valve Body ??'s
Valve Body ??'s
Do the JW or BTS Valve Bodies make a huge difference in the shifting on the 4R100?
I tow a 10,000 lb 5ver, and it seems that when towing in the 60 tow mode on the DP, There is a lot of "searching" in the 40 to 45 MPH range even with the OD off.
Just wondering if the VB upgrade would be worth it
All feedback as usual, is appreciated, and will surely lead to more questions
I say mod your own and save some jack. The TransGo kit is $70-$100 depending on which one (I say get the Tugger since you tow). You'll need to get your tunes updated to match the new VB though. Theoretically, the JW VB needs no tuning updates, HOWEVER, since you're dealing with a searching problem, I don't think the VB mods will fix that. I still suggest it, but not to fix your problem. That should be fixable in tuning only. My $0.02......
Do you mean frequent upshifting/downshifting/upshifting or
Do you mean that the shift points aren't dependable, given the same conditions each time.
Pop
Also, when slowing down for a sharp turn , it seems to hold the higher gear when I try to accelerate out of the turn, It almost feels to me like a gas powered engine doing what we called "dieseling" if that makes sense.
wildstang
1999 to 2016 Super Duty
05-11-2010 11:30 AM
