02 explorer is missing
Old Oct 23, 2009 | 11:16 AM
luke21er's Avatar
luke21er
Hello I own a 2002 explorer it has around 84000 miles, we have been having a problem with it now for awhile. Just about every morning when you start it up first thing it sits there and chugs like it is missing and about to stall out. Once you put it in drive and take off it will do it for a few more seconds and then it quits and for the rest of the day it is fine. Except the next morning it will do it all over again. Does anybody have any idea or suggestions?
Old Oct 23, 2009 | 05:48 PM
marragtop's Avatar
marragtop
Try pulling the codes. There may be a code stored even if the CEL is off. Consider doing a tune up and/or cleaning the IAC and MAF.
Old Oct 23, 2009 | 09:23 PM
steve(ill)'s Avatar
steve(ill)
mar has a good idea. your not using any antifreeze are you? level is full?
Old Oct 23, 2009 | 09:24 PM
steve(ill)'s Avatar
steve(ill)
does it start up quick or take several seconds to startup? leaking fuel regulator will cause blead off overnight and long cranking, poor running the next day for 10-20 seconds.
5.0 Heaven
1978 - 1996 Big Bronco
Feb 12, 2013 07:21 AM
Copedawg
24
Sep 11, 2010 09:25 PM
phil6608
Delaware Chapter
24
Jul 30, 2007 07:06 PM
911bear
Apr 8, 2007 05:35 PM
mroberts
Feb 3, 2004 06:45 PM
