Bad intake valve?
Old Oct 23, 2009 | 12:53 AM
Iman901's Avatar
Iman901
Bad intake valve?
So, I just got an 84 f250 diesel, it starts easy but has a dead cylinder, it seems to be losing compression through the intake on the #5 cylinder, it makes a chugging noise that just gets louder when it revs up. There is also white smoke coming from the exhaust once it has warmed up, the smoke pulses in rythem with the engine.
Could I have a bad seat or burnt valve that is causing this? I was thinking it could also be a stuck lifter since the truck sat quite awhile before I got it.
Old Oct 23, 2009 | 02:18 PM
PLC7.3's Avatar
PLC7.3
Both your ideas are good, best to remove the valve cover and check for the lifter/valve operation.
Old Oct 24, 2009 | 12:48 AM
87crewdually's Avatar
87crewdually
Could also be a blown head gasket and pushing unburnt fuel and pressure to the adjacent cylinder which at that time could have an open intake valve, hence the popping through the intake. Check compression in the adjacent cylinder. Also you can bring problem cylinder to TDC of compression stroke and put air pressure through the glow plug hole and listen for the passing of air through the intake and/or the adjacent cylinder glow plug hole.
BigBlockF350
Apr 22, 2013 12:55 PM
fx4hauler
Aug 16, 2009 09:36 AM
PHOTOG101
Sep 9, 2005 12:20 AM
KJKozak2
May 23, 2005 08:02 AM
CantDrive55
Dec 6, 2000 07:17 AM
