hey there i have a very good friend that has a 2001 f-350 dump truck dually 4x4 auto trans and it has some codes that im not really sure on what they mean and what it is trying to tell me lol if you have any help for me im a greatful man and the truck is not get a signal from the gas petal but the petal is in good working shape i tested on my work truck and it work on it so i know it not the petal but it still not moving the RPMs plz help me guys im new to the 7.3
P0221-thr/pedal pos sns switch-B perform
P0603-internal ctrl module kam error
P1690-wastegate solanoid ctrl ckt fault
P1119-manifold air temp sensor ckt high input
P0122-thortel-pos sensor A ckt low input
P1280-ICP ckt out of range low
Sounds like the throttle position sensor or idle validation sensor in the pedal assembly is bad. You're saying his pedal works fine in your truck? How does your pedal work in his?
well from wht she tell me it hs not no mod done to it but people do lie so and i didnt take my pedal out cuz it was easy to just plug it the one in to my to see if it works and it did so i feel like its not the pedal but i could be wrong ill try in the am
