I'm confused
Old Feb 28, 2012 | 07:37 PM
fordpride's Avatar
fordpride
I'm confused
I stopped at the store put my truck in park and it sputtered twice then died. Checked codes and got
P0712 Transmission Fluid Temp. Sensor CKT Low Input
P0197 EOT Sensor Circuit Low Input
P0713 Transmission Fluid Temp. Sensor CKT High Input
Checked oil and was a gl. Low. Filled the oil started cranking and after about 20-25 sec it started and ran fine. If it was the oil that was my issue then why those codes?
Old Feb 28, 2012 | 07:45 PM
427 fordman's Avatar
427 fordman
I don't know but I'd clear them and see what happens. Why were you a gallon low? Got a leak?
Old Feb 28, 2012 | 07:55 PM
fordpride's Avatar
fordpride
Yea oil cooler leaks for the first few mins. of a cold start
Old Feb 28, 2012 | 07:56 PM
fordpride's Avatar
fordpride
Could those codes have come when the truck died with the key on and the PCM got confused ?
Old Feb 28, 2012 | 08:17 PM
427 fordman
I'm not sure, but that is what I was kinda thinking, maybe when it sputtered and died a few came up. Those specific codes made me think that, as in all sensor related, but like I said, I'm not sure, but I'd just drive it and pull them later and see what you come up with.
Old Feb 28, 2012 | 08:20 PM
Action4478's Avatar
Action4478
You may have more than one problem ...THe only code that may be related is the EOT code
Old Feb 28, 2012 | 08:38 PM
fordpride's Avatar
fordpride
After it was running I looked over all the sensors on my scangauge and all looks normal.
The trans codes is what has me confused.
I did have a fuel leak by the FPR so I'm gnna check all the wiring tomorrow
Old Feb 28, 2012 | 09:35 PM
Action4478's Avatar
Action4478
DO you think (FCOL) this had anything to do with it?
Old Feb 28, 2012 | 09:51 PM
fordpride's Avatar
fordpride
what's FCOL
Old Feb 28, 2012 | 10:00 PM
oldbird1965's Avatar
oldbird1965
Subscribing, It was either a long day or I'm having a brain fart, what is FCOL? I don't feel like looking it up, LOL (lazy)
Edit: You beat me Mike.
Old Feb 28, 2012 | 10:28 PM
jiveturkey692000's Avatar
jiveturkey692000
For Crying Out Loud? Lol.
Old Feb 29, 2012 | 06:05 AM
427 fordman
If you've got an idea or know what is going on, most of us (Mike especially) would like to know, instead of whatever answer that is.. I know I'd like to know, that is why I said I'm not sure. Remember, most of us are still learning..
Old Feb 29, 2012 | 06:35 AM
fordpride's Avatar
fordpride
I really dont think low oil is my problem. Low Oil will not set any of those codes. I think I have a wiring issue.
When it I died I checked codes and got those and while cranking my DC was getting up to 40% and ICP was 2500 with lots of smoke. I had 317 rpm, 12.1v and 73psi fuel pressure. So every condition was there for it to start but it would not fire off
Old Feb 29, 2012 | 11:22 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
FCOL For Crying Out Loud
FCOL Flip Chip on Leadframe (assembly technology; trademark of Carsem)
FCOL Football Club Olimpija Ljubljana
Old Feb 29, 2012 | 11:24 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Or maybe if readed inverse (as Rick and Bill [rip] used to do)
LOCF Last Observation Carried Forward (psychiatric clinical reseach)
LOCF Love of Christ Fellowship
