Sponsored by: Real Truck
spindle bearing number for F350 4x4
Old Oct 22, 2009 | 10:29 AM
arriero's Avatar
arriero
hi all, i need if someone can give me the spindle bearing numer in Timken or SKF. I need to replace them on my 03 F350 4x4 6.0.
Thanks a lot.
arriero
Chile
Old Oct 23, 2009 | 05:58 AM
DJR96's Avatar
DJR96
Wink
Someone correct me if I'm wrong, all the late model F250's and F350's use the same housing/spindle and wheel hubs.
The outer bearing is an LM 104949 (SKF or Timken)
Inside diameter =2",
outside diameter =3.25 ",
Thickness =0.85".
And the inner bearing is Timken #NP114036, or SKF 382 A.
Inside diameter =2.25",
outside diameter =3.8125 ",
Thickness =0.827".
You'll be horrified at how close together the bearings are. As tough as they are, they're not infallible.
Old Oct 23, 2009 | 10:18 AM
cartmanea's Avatar
cartmanea
2wd and 4wd are completely different
Old Oct 23, 2009 | 05:22 PM
DJR96's Avatar
DJR96
Wink
The info I gave is for the rear axle. Arriero said he has 4WD, so spindle bearings I assumed must be for rear axle.
Yes 2WD has similar bearings on the front. And 4WD has the unit bearing hubs, very different designs indeed.
Old Nov 14, 2009 | 07:00 AM
arriero's Avatar
arriero
hi guys,
it's the front axle. I just teared everthing appart. The problem was the needle bearings. it cost me 6 buck each and took me 2 hours in my garage to change them. No special tools. Napa number B-2110 (best), or BA-2110. I'll post some pics in a few days.
thanks all.
Old Nov 14, 2009 | 08:32 AM
bismic's Avatar
bismic
Originally Posted by arriero
hi guys,
thanks all.
Glad you got it fixed. Look forward to the pics.
Old Nov 25, 2009 | 07:20 AM
arriero's Avatar
arriero
Everyting appart
Needle bearing. On the left the BA2110, on the right the old messy B2110
Wheel bearing with needle bearing out
Hope it helps. I used a hammer and a wrench extension to put it appart.
See you guys
Old Aug 8, 2010 | 03:59 PM
79 bronc's Avatar
79 bronc
Arrerio,
Did you really disassemble the hub unit??? From everything i've read, its not a servicable part. I also heard the the hub is spring loaded and if one is to disassemble it, all all hell woud bust loose in your face.
Looking at your photos again, did you just punch out the old bearings and press in the new ones? If so good idea.
Old Aug 8, 2010 | 09:34 PM
arriero's Avatar
arriero
Originally Posted by 79 bronc
Arrerio,
Hi 79 Bronc,
Yes, y just hammered out the needle bearing. I used a long piece of tube from the opposite part of the spindle. Hammered a couple of times until it got out. Then just press the new needle bearing in. The spindle bearing unit is not serviceable, but you can change the needle bearing.
good luck.
arriero
Old Aug 10, 2010 | 09:46 AM
79 bronc's Avatar
79 bronc
Hi 79 Bronc,
good luck.
arriero
That is awsome. I'm on my second set of hubs. The first set lasted may be 40k miles. I'm running 38" tires and that eats them bearings up. I'm surprised no one else has talked about poppin out the old needle bearings. Again Awsome, I'm going to replace mine to night. I'll post a follow up with bearing numbers for other guys. I'm running a 2003 f350 srw 4x4 with abs.
Thanks for the reply.
Old Aug 10, 2010 | 10:07 AM
arriero's Avatar
arriero
I have the same truck, same year, running tires not so big, just 285/75r16 Trxus MT in OEM rims and planning to move to same size, KMZ2 but R17 in a 10 inch rim.
I live really far away from the states, so every spare is really expensive, so we get creative, without compromising safety. That´s why I just changed the needle bearings.
Just as an example: a spare that costs 200 bucks in the states, I have to pay 450 bucks approx. in Chile....
Old Aug 10, 2010 | 10:30 AM
79 bronc's Avatar
79 bronc
send some pictures of your ride from down there.
Old Aug 10, 2010 | 11:16 AM
arriero's Avatar
arriero
here, a picture. This was taken during the Dakar Series 2010 in the Atacama Desert. I was in the group of route safety.
http://img130.imageshack.us/img130/5...1ffc67ffbb.jpg
Old Aug 10, 2010 | 11:28 AM
Maxium4x4's Avatar
Maxium4x4
Moved to SuperDuty.
Appears to be a dog on the hood...
Old Aug 10, 2010 | 02:16 PM
arriero's Avatar
arriero
Originally Posted by Maxium4x4
Moved to SuperDuty.
Yep, I was not allowed to carry my rottweiler, so my gfriend bought a fake one and put it on the hood...
bcaughhorn
Jan 25, 2016 08:31 PM
MtHydro
Mar 6, 2012 10:40 PM
sckootter16
Jun 16, 2011 06:29 PM
jmczzz
Apr 27, 2011 09:53 PM
