Pitman Arm Help -What Year Will Work
Old Oct 20, 2009 | 08:28 PM
taylorjgreen's Avatar
taylorjgreen
I am putting a Ford (saginaw) power steering box in my 65F100. My question is with the pitman arm, as the power steering box I got did not come with one.
All the trucks this age have been wrecked around here so getting a part from a wrecker is almost impossible. I found one on Ebay that the seller says is for a 69-72. Based on my understanding, everything should fit up to 79.
What will work with this steering box? I can get the part number of the steering box if needed. Also the front end (drag link) is from a 76, if this matters
Old Oct 21, 2009 | 03:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by taylorjgreen
I am putting a FORD power steering box in my 65 F100. My question is with the pitman arm, as the power steering box I got did not come with one.
There is no part number on the gearbox. Only...as original...an ID tag...which may be missing by now.
The ID tag is not necessary, because the 1969/79 Ford P/S gearboxes are essentially the same.
However...there are several different Pitman Arms and draglinks used on F100/150's.
I suggest you ask jowilker or banjopicker what will work.
flamesoldier
Feb 11, 2013 10:04 PM
okedokeno
28
Oct 26, 2012 10:45 PM
DemonRace6
Sep 13, 2011 01:19 PM
fordxxx
Sep 22, 2004 02:07 PM
HardFordCore
Nov 30, 2003 01:02 PM
