Power steering conversion-pitman arm
Old Sep 9, 2003 | 10:38 PM
HardFordCore's Avatar
HardFordCore
Finally I am getting around to doing a power steering conversion on my 66 Shortbed. I have one question that I can't find the answer to. What pitman arm should I use, the original from the manual box or the donor arm from the later model? Thanks to anyone can send me in the right direction.
Mark Hebard
Old Sep 10, 2003 | 03:54 AM
banjopicker66's Avatar
banjopicker66
Most likely, you will need to use the donor pitman arm. The splined shaft holes for the gearbox are different for the manual in '65 and '66.
the donor pitman should be the same dimensions, though. The important one is length. (The tapered mount hole for the linkage stud will be the same, so you have no worries there, if it is from a 67 - 79 truck.)
Old Sep 10, 2003 | 08:34 AM
6t6merc's Avatar
6t6merc
Mark - I used the Bendix box and found that the original Pitman arm wouldn't work. I'm a little ashamed to admit that my steering expert gave me a GM piece that works great.
Eric
Old Sep 10, 2003 | 08:59 AM
banjopicker66
Before I did this conversion, I measured a lot of pitman arms for the Ford boxes. I ended up using the Bendix box like Eric did, but mine came with the donor's pitman arm. I found the pitman arms for all 15 or so 2WD Ford trucks (that I measured - there may be exceptions) from '65 up to '78 are the same length, and the tie rod hole is the same size and in the same place.
The differences come into play at the pitman arm to gearbox hole. The hole there is different sizes.
It is best if you can get a donor arm with the box.
Here is a summary of what I found. Keep in mind Ford did some strange things, and my sampling is not that large, so there are probably exceptions:
Manual gearbox '65 and '66: Match, no alternates.
Bendix gearbox '65 to '70: Match, no alternates.
Ford gearbox '67 to '78 (possibly '79, I never saw one to measure): Match, no alternates.
If you cannot find a match, be sure to get with Eric (6T6Merc).
Old Sep 11, 2003 | 11:05 AM
William's Avatar
William
Donor! And core the box before you go through the hassel of installing it only to discover it is worn or the PS don't work.
Old Nov 30, 2003 | 01:02 PM
65f100CoryE.'s Avatar
65f100CoryE.
I did my conversion and I found that the donor pitman arm was ok and works
but the angle was a little different where the link bolts up the pitman arm.
leonharu
16
Mar 23, 2017 07:53 PM
Zazoos
Jul 21, 2015 03:06 PM
1965f100123
Jan 28, 2012 05:35 PM
glenn Allen
Oct 12, 2008 09:49 AM
pcta12
Sep 11, 2006 12:57 PM
