4x4 problem
Old Oct 19, 2009 | 05:56 PM
michael cook's Avatar
michael cook
4x4 problem
I got in my 2006 lincoln tonite to pull 2 bishes out of the yard. I went to put it in 4 low and nothing happened would not go in 4 hi either had trany in neutral foot on brake?? when I start it up the lights for 4x4 light up so I no they are not burnt out any ideas ?? had it in 4lo about 2 months ago to pull trailrer out of field and it worked fine then!!
Old Oct 19, 2009 | 10:26 PM
fordtruckman's Avatar
fordtruckman
Solenoid? When my 4x4 wouldn't engage it was from the solenoid, they replaced that and everything worked.
Old Oct 20, 2009 | 01:30 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
take a small hammer and lightly tap on the t-case shift motor.
the t-case motor gets corrosion in it and "freezes". the hammer tapping will loosen up the frozen parts/pieces.
not a lasting correction unfortunately. it will work for a while, but eventually the corrosion will be too bad and you'll have to replace that motor
Old Oct 20, 2009 | 01:31 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
once you get it working, it's a good practice to shift into 4x4 at least 1 time per month.
keeps thing working and lubricated. those who do are less likely to have the problem occur
Old Oct 20, 2009 | 07:26 PM
michael cook
4x4 problem
I hit it with a hammer very lightly a copule of times then tried it works great will engage it a couple of times a month from now on thanks for the help
rutnstrut
Sep 9, 2013 04:05 PM
avengermike
Nov 21, 2012 03:39 PM
CircleV
Jun 3, 2008 08:05 AM
jodypbeck
1997 - 2003 F150
Mar 6, 2005 04:44 PM
clava
Jan 6, 2004 09:50 PM
