Sponsored by: Real Truck
4x4 not engaging HELP
Old Sep 6, 2013 | 04:34 PM
rutnstrut's Avatar
rutnstrut
I have a 2002 Ford Superduty. I recently had installed a BDS 8 inch suspension lift. I also had the upper and lower ball joints replaced. All this work was done by a certified garage. Today i went to pull out my boat from the ramp, turn the switch inside the cab to 4x4 high. The light came on but 4x4 did not engage. As i pulled the boat out of the water the rear tire spun in the sand but the front did not. As i cleared the ramp and on level ground i turn the switch off and back on i heard not but the light can on. With the 4x4 light on i turn the wheel and pulled forward i noticed no hopping as when a truck is in 4x4. Initially when i turn the 4x4 switch on i hear a clunk up front but not after. Drove home drive tran appeared fine no noise.
Old Sep 9, 2013 | 08:20 AM
kefrko's Avatar
kefrko
Is your truck diesel? Could be a vacuum line issue. I have been messing around with mine because the air vents sometimes only blow out of the defrost vents no matter where the switch is set (most likely due to a vacuum leak in the system somewhere). Do you have ESOF hubs where you can also lock them manually? If so I would see if you can lock them manually and see if the the 4x4 engages. You might not have noticed but try putting your air conditioning on with the blower running and switch the 4x4 switch and see if it switches up to the defrost vents. If it does it could be a vacuum leak.
Old Sep 9, 2013 | 08:23 AM
senix's Avatar
senix
This points to a vacumn leak.
Manually turn the hubs then do the switch and it should still engage till you find the leak.
Old Sep 9, 2013 | 04:05 PM
donovan's Avatar
donovan
8 inch lift
When the shop did the 8 inch left did not connect the vacuum lines. Best to have look for yourself before taking the truck back.
Troy_455
Jul 13, 2015 08:37 AM
Vinford
May 30, 2015 04:29 PM
kingair41
Dec 7, 2012 12:31 PM
BWPowersmoker02
Jan 2, 2010 02:33 PM
Floater
Aug 7, 2007 07:08 PM
