Heat/ac control problem!
Old Oct 13, 2009 | 08:53 PM
cdestuck's Avatar
cdestuck
I have a ongoing problem with the heat control in my 08 Lariat. Heat control has the digital numbers and has both an AUTO setting or butons to push for the different vent levels. when putting the digital display even down to 65, it keeps blowing heat even though it get way past 65 defrees. The next lower degree setting is 60. When you display t60, then all cool air. seems like there is no regulating or slowing of the heat when the cab reaches the set temp. Dealer just scratches his dumb head. anyone else here go though that problem? Thanks
Old Oct 13, 2009 | 10:19 PM
kenwowski's Avatar
kenwowski
it sounds like your blend door actuator....I had it replaced on my 07' and it was doing the same thing...if you poke around this site you will find a TSB for it
Old Oct 14, 2009 | 12:49 PM
rcaddell's Avatar
rcaddell
+1, my 08 was either full hot of ice cold, no middle of the road. Took it in and IIRC, the invoice said Blend Door.
Old Oct 14, 2009 | 06:11 PM
air1jpg's Avatar
air1jpg
+2 my 06 did the samething. There is a re-designed blend door motor. I am a bit surprised the 08 models are affected by this..
Old Oct 14, 2009 | 06:38 PM
cdestuck's Avatar
cdestuck
What does IIRC mean? and thnaks for the replies, will relate these to the dumb service folks.
Old Oct 14, 2009 | 06:42 PM
BearFootCustom's Avatar
BearFootCustom
My dads 08s doing the same thing
Old Oct 14, 2009 | 06:43 PM
rcaddell's Avatar
rcaddell
IIRC - If I Recall/Remember Correctly
Old Oct 14, 2009 | 09:21 PM
SMok's Avatar
SMok
it is the bleen door actuator causing your problem
Old Oct 20, 2009 | 08:52 PM
eatingdead's Avatar
eatingdead
my 07 does the same thing. i have been dragging my feet on the repair. I assume this is not an easy install. Although I ahvent looked either..
mblayton
Feb 9, 2013 09:44 PM
BlackstarF250
Apr 2, 2011 03:47 PM
Bax2008
Aerostar
Feb 6, 2008 12:14 AM
jokerswild130
Dec 31, 2006 12:07 PM
cody47
Aug 9, 2005 03:10 PM
