Sponsored by: Real Truck
ESOF problems/ Insight
Old Nov 19, 2012 | 11:56 PM
avengermike's Avatar
avengermike
hey guys so like many went to use my ESOF 4x4, and i have never had any problems but to day it wouldnt go in to 4x4. pulled the plug off the switch and none of the wires have power, so im thinking my trucks brain for 4x4 died. I looked at some wire dig and studied the web, came up with some push switches that ground my relays. my problem is i thought the 4x4 lights would light up so i know when its in hi and low. No such luck, if i ground it one way till i hear a click i have 4 low and if i hit the other switch to a click 2 hi. I did go out and mess around in the truck and would hold the switch for sec in the direction of low and i could catch 4 hi but im worried that maybe i dont have the grears lind up perfect. so finally to my question is their a way to get the lights on the dash to work?
thanks for any help
Old Nov 20, 2012 | 05:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
Hello avengermike and welcome to FTE.
From what I have been told, the lights in the dash are controlled by the shifting motor on an ESOF system.
Old Nov 20, 2012 | 11:29 AM
avengermike
if thats the case i must have something wrong, cause when i use my push button set up i cant get lights to come on but truck is in 4x4.
Old Nov 21, 2012 | 12:28 PM
basket1021's Avatar
basket1021
I have the same issue. I have kind of given up fixing it since I know the truck is in 4wd. The light does not come on. I tried to replace the 4wd module behind the glove box, but to no success. Let me know if you get your light to work. Hopefully somebody will be able to chime in on this
Old Nov 21, 2012 | 03:39 PM
EXv10's Avatar
EXv10
Check all your fuses too, and wiring for shorts and the bulb.
HosSeagull
Nov 7, 2017 06:41 PM
DEMIGOD
Feb 13, 2014 03:09 PM
m350
1997 - 2003 F150
Feb 2, 2008 12:40 PM
montananord
2004 - 2008 F150
15
Nov 2, 2006 02:54 PM
riley42204
May 10, 2005 02:13 PM
