Heated seats
Old Dec 31, 2009 | 10:07 AM
  #31
jeff7825's Avatar
jeff7825
Originally Posted by billcollector
The light on my switches do not come on. Where is the fuse, and relay for the heated seats? What else might be wrong?
The relay is under the driver's seat I am pretty sure. The fuse would depend on the year, on my 01 is shows the fuse being under the hood in the power distribution box. I think in 02 and above, the fuse is under the dash.
Old Dec 31, 2009 | 02:59 PM
  #32
crocodiledendy's Avatar
crocodiledendy
Light in heated seat swithes
The diagram I have is for an 04. The pages I have do not show the wiring for the light in the switch itself. A hot white/red wire goes to the switch from the seat relay. When pushed on a yellow/light blue wire carries juice from the switch to the seat cushion and from there a gray/light blue wire goes to the seat back. If your seat heat and back heat is all working, it looks like the problem would have to be a broken wire to the light. Should be a black wire that goes to ground. Should be a easy test an electrical tester. Otherwise, it should be the light itself. The only fuse I am showing on my schematic works the entire system. My is located in the main fuse box. I went to the Ford dealer and they were happy to run these pages off for me. Hope this helps. I by far not an expert.
daddgonemadd
Apr 22, 2020 03:18 PM
gspv
Mar 6, 2017 04:40 PM
MTDOG
Nov 9, 2016 09:52 PM
clifish
2011 - 2019 Explorer
Oct 8, 2016 04:03 PM
gsxr1300
6.7L Power Stroke Diesel
33
Jan 5, 2014 08:08 PM
