4x4 floor shifter
Old Dec 30, 2009 | 01:17 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Angry 4x4 floor shifter
My 4x4 floor shifter is not staying in, it will in 4-high to a point but pops out, but I try and put it in 4-low and the lever just snaps forward. It will drive in 4-low if I hang on to the the lever. Is there a detent that might be worn?
Thanks, Bill
Old Dec 30, 2009 | 07:31 PM
camodown's Avatar
camodown
Hmm, not sure, but maybe there is an internal retainer or detent like you said... Here's a bump for you...
Old Dec 31, 2009 | 09:22 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Ideas anyone?
Old Dec 31, 2009 | 10:13 AM
Pikachu's Avatar
Pikachu
Although I can't say for certain with regard to a transfer case, when I had a transmission that did the same thing, it had to come out for repair. It's been so long now that I don't remember what internals were replaced, however.
Old Dec 31, 2009 | 10:32 AM
jasonch's Avatar
jasonch
this happend to a dodge i use to have, there was a clip in the transfer case on it, or at least thats what they told me. i just sold it! have you traced it down to the transfer case from the shifter? maybe there is something obvious there, im not sure. good luck!
Old Dec 31, 2009 | 11:31 AM
4inchlovin's Avatar
4inchlovin
could it be a tranny mount that has gone out???
Old Dec 31, 2009 | 12:06 PM
camodown's Avatar
camodown
can you put the truck into 4x4 and then disconnect the lever at the T-case and see if it still pops out? That would eliminate or prove the lever being the cause..
Old Dec 31, 2009 | 12:18 PM
jasonch's Avatar
jasonch
if it is like my problem, it will go in and kick out ok, it just kicks out of 4wd while your driving, like it never truly locks into 4wd. just my 2 cents.
Old Dec 31, 2009 | 02:02 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I found and fixed the problem: The bolt that holds the shifter to the side of the trany is in a nylon sleeve that is inside a bushing that is surrounded by a rubber bushing. It seems that the whole mess was corroded. The reason the shifter was springing forward was just probably lack of not being used often enough. A little grease will keep it working awhile. Maybe a good place for a grease zerk.
Old Dec 31, 2009 | 02:05 PM
jasonch's Avatar
jasonch
congrats on the fix!
Old Dec 31, 2009 | 02:42 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Thanks, I can see why it freezes up, it has just a small range of travel.
Old Dec 31, 2009 | 03:01 PM
Excursion4X4's Avatar
Excursion4X4
Good Job! I like easy fixes!
