dana 60
Old Oct 17, 2009 | 07:38 PM
jb65542's Avatar
jb65542
dana 60
hi i was just wondering if a dana 60 under the rear of a 1968 f100 4X4 is rare and if they are much better than the nine inch you see under most f100s, also what gear ratio do they come with
Old Oct 17, 2009 | 08:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Are you sure it's a Dana 60, and not a Dana 44 rear axle? *
1967/72 F100: The Dana 60.3 (with/without Limited Slip) was an option.
The 60.3 is a semi-float rear axle, not the same rear axle as a Dana 60 full float rear axle.
Dana 60.3 axle ratio's:
Without Limited Slip: 3.54-1 / 3.73-1 / 4.10-1 / 4.56-1.
With Limited Slip: 3.54-1 / 4.10-1.
The Dana 60.3 uses the same 5 lug, 5.50" bolt circle wheels as the 9 inch.
* All 1959/67 F100's, some 1968 F100's: When Limited Slip is present, the rear axle is usually a Dana 44.
You could not get a 9 inch rear axle in an F100 with Limited Slip until midyear 1968.
Old Oct 17, 2009 | 08:18 PM
jb65542's Avatar
jb65542
im not sure, i do know that it is the same 5x5.5 bolt patterm, but how do you tell, i think it is the 3.54 gears and it is limited slip
Old Oct 17, 2009 | 08:19 PM
jb65542's Avatar
jb65542
also thanks for the quick reply
Old Oct 19, 2009 | 03:26 PM
mk's Avatar
mk
dana60
I pulled a 60 out of a 67 F100 this summer with the 3.54 locking setup. The model number (44 or 60) is cast into I think the lower right corner of the rear of the housing. There should also be a tag with the ratio on it attached to the cover.
mike
Old Oct 19, 2009 | 07:39 PM
jb65542's Avatar
jb65542
it does have 60 on the corner of it
jodyreed71
Jun 30, 2014 10:45 PM
The Freak
Dec 29, 2010 02:20 PM
kristie
Offroad & 4x4
17
Feb 14, 2009 12:03 PM
jimbo beam
General Automotive Discussion
May 8, 2006 10:45 AM
RedXL
Mar 19, 2003 03:46 PM
