wheel wont come off
Old Oct 16, 2009 | 12:38 PM
camo1987f150's Avatar
camo1987f150
wheel wont come off
i have a 94 explorer and i was trying to take the back wheel off and it wouldnt come off it is an aluminum wheel. Is there a trick to get them off or is it just corroded on?
Old Oct 16, 2009 | 01:45 PM
aquanaut20's Avatar
aquanaut20
Probably just corrosion, loosen of wheel lugs a cple of turns, spray PBlaster on hub/wheel joint, drive slowly in zig-zag pattern, should break free.
Old Oct 17, 2009 | 03:04 AM
Ed's Avatar
Ed
Holy cr*p, don't drive on it. That will simply ruin or weaken your studs. The PB Blaster application should do the trick, if nothing else, jack up the Explorer and take the weight off of the wheels. Let it sit overnight, the lug nuts and wheel should be able to remove easily.
Where are you located Camo1987? I've had beater winter rides when I lived in Ohio during the 70s and early 80s, I never had a wheel I could not remove.
Old Oct 17, 2009 | 09:01 AM
shorod's Avatar
shorod
It certainly isn't uncommon to have alloy wheels corrode to the brake rotors, and often Blaster or similar is not sufficient to break them free. Beating on the wheels with a dead blow hammer is not good for the body and often it's quicker (and plenty safe) to just barely loosen the lugnuts, then move the vehicle at idle speed a few feet and apply the brakes. I wouldn't loosen the lug nuts a couple of turns, just enough that they are not making a tight contact to the wheel.
Once you get the wheels off, you can clean the surfaces then apply a very light application of anti-seize to the wheel hub. A very light layer is sufficient, don't apply so much that it can migrate to the braking surface of the rotor.
-Rod
Old Oct 17, 2009 | 12:02 PM
aquanaut20's Avatar
aquanaut20
I certainly wasnt advocating the he DRIVE with loose studs/wheelnuts.
Shorod obviously got the gist of my comment, and 2 turns gives about 1/8" slack, just enough to have the wheel break free from the flange. Thanks.
Old Oct 18, 2009 | 11:35 PM
camo1987f150
it was just corroded. all i did was take a big sledge hammer and it the side of the tire and it came right off. I live in missouri but i just bought the explorer so i guess they didnt ever rotate the wheels because the tire recipet was from 2001
bigtexan99
Dec 27, 2011 02:44 PM
93XLT150
16
Feb 19, 2011 08:47 PM
hopperwagonbob
1997 - 2003 F150
Nov 18, 2010 08:02 PM
Saz221
Dec 21, 2009 02:32 PM
