boss
Old Oct 16, 2009 | 03:12 AM
Draken's Avatar
Draken
boss
two questions, will a standard 302 block accept a solid cam?
second i want to make a boss 302 clone, is it possible and how would i do it, i know Cleveland heads and intake but what else?
Old Oct 16, 2009 | 04:01 PM
doug1222556's Avatar
doug1222556
Yes, a standard 302 block will accept a solid flat tappet cam.
Besides the heads, the actual Boss 302 had 4 bolt mains. Besides the heads and intake, you will either need new pistons or have to re-work the ones you have. You have to drill some holes for the water passages.
Unless there is some specific reason for wanting to do it, I wouldn't. Aftermarket aluminum heads will out flow the Clevelands and be a lot easier and probably cheaper than getting all the parts for a Boss clone.
It was cool a while back, but I don't know of anybody that thinks it's worth it now.
Old Oct 16, 2009 | 04:11 PM
doug1222556
Here's a link to some more info about what you want to do:Track Boss ME 2005.
Old Oct 16, 2009 | 04:49 PM
Draken's Avatar
Draken
i cant afford new cylinder heads and i have most of the parts already, im just wondering if cleveland pistons will fit into a 302 block, when i look up boss pistons it comes up for both 302 boss and 351 cleveland, and i know the cleveland has a 4 in bore like a 302, all i need is gaskets and cam really.
Old Oct 16, 2009 | 05:06 PM
doug1222556
There are 3 things that determine whether a piston will fit or not. Bore size, pin size, and CH. You need to match those up.
TMI
Oct 15, 2008 08:29 PM
Beanscoot
Nov 6, 2007 06:11 PM
polk05
Oct 12, 2002 12:12 PM
335clevo
May 27, 2002 06:48 PM
335clevo
Apr 12, 2002 09:43 PM
