302 Clevelands
Old Sep 27, 2001 | 07:16 AM
335clevo's Avatar
335clevo
302 Clevelands
Hello all
Just wondering, in Australia the 302 Cleveland is pretty common. It was not sold in the usa was it? I know the 302 windsor was but i don't think the 302 cleveland was. thanks for your help,
335C
Old Sep 27, 2001 | 10:24 AM
Bill_Beyer's Avatar
Bill_Beyer
302 Clevelands
Nope, the 302C was never offered in the states.
Old Sep 29, 2001 | 05:53 PM
onebad40willys's Avatar
onebad40willys
302 Clevelands
The only version of the 302C is the 302 bossfound in the stang's
Old Sep 29, 2001 | 11:10 PM
Christian's Avatar
Christian
302 Clevelands
From what I can gather, you'd be hard pressed to find a set of closed chamber 2V Cleveland heads in the US. These were cast in Australia to be used on 302C engines, in order to keep the compression up (about 9.5:1). You can use these on 351C engines, but the comp. goes up to 12:1 or higher (like 4V closed chamber heads) and hence special fuel is required. Also, The Boss 302 was a windsor block, wasn't it? (with cleveland heads?)
Old Oct 5, 2001 | 02:16 AM
Ratsmoker's Avatar
Ratsmoker
302 Clevelands
That's a good question Christian. I always thought that the boss 302 was a 335 block but then again I have right next to no knowledge on this engine family.
Old Oct 5, 2001 | 04:53 AM
335clevo's Avatar
335clevo
302 Clevelands
Hi, Back again,
Yes I know about the Boss 302, you're correct, it was a 302 Winsor block with Cleveland heads. The 302 closed chamber heads are as common as mud here in Australia, and I belive they are sought after in the USA.
335C
Old Feb 11, 2002 | 03:55 PM
dzjammer's Avatar
dzjammer
302 Clevelands
Old May 27, 2002 | 01:08 PM
EvilKty's Avatar
EvilKty
302 Clevelands
Just q quick question.. What would be the shipping to send a set of Aussie 351C heads to US?
Old May 27, 2002 | 06:48 PM
xyfalcon500's Avatar
xyfalcon500
302 Clevelands
Remember, it's not aussie 351C heads you want, as these are identical to US 2v 351C heads. You want Aussie 302C heads, with the small combustion chambers.
F-250 restorer
Jun 28, 2014 08:09 AM
Greg Crofts
Large Truck
Aug 20, 2012 02:36 AM
polk05
Oct 12, 2002 12:12 PM
335clevo
May 6, 2002 08:13 AM
335clevo
Apr 12, 2002 09:43 PM
