Sponsored by: Real Truck
Remote Start
Old Oct 15, 2009 | 07:35 AM
musclecars90's Avatar
musclecars90
Remote Start
A friend of mine has an 08 Chevy 2500 Duramax and he has a remote start on his truck. Is it possible to have one on a 04 6.0L Diesel. Would it be safe since you have to wait to in the on position before starting it?
Old Oct 15, 2009 | 07:39 AM
edjunior's Avatar
edjunior
The CodeAlarm I have has a delay that can be set especially for diesels. Most remote starts have that option, but be sure and ask before you buy.
Old Oct 15, 2009 | 08:15 AM
BIG BLUE BEAST's Avatar
BIG BLUE BEAST
Talking
had the dealer install a remote start om my 09 psd. it has about a 45 second delay. works real good.
Old Oct 15, 2009 | 09:13 AM
aldridgec's Avatar
aldridgec
Some also have the option to tie into the wait to start light, but the Ford doesn't have a dedicated signal wire, it's through the data bus. So you just have to have a delay programmed. I turn mine off in the warmer months, but will have to turn it back on soon.
Old Oct 15, 2009 | 11:34 AM
musclecars90
would i better off going with a oem if ford makes one or an after market
Old Oct 15, 2009 | 12:14 PM
aldridgec's Avatar
aldridgec
Either way they are both aftermarket, just one is sold and marketed by ford. I also think if it's installed through the dealer, the Ford one is covered under the warranty. Last I heard it was manufactured by code-alarm. Neither one will give you an integrated delay tied to the wait to start.
Old Oct 15, 2009 | 03:49 PM
sdetweil's Avatar
sdetweil
did you mean 'either' instead of 'neither'?
above sounds like dealer installed DOES get connected..
Sam
Old Oct 16, 2009 | 11:07 PM
ford7379trucks's Avatar
ford7379trucks
the aftermarket ones are alot cheaper. i think they all come wit ha programable delay for diesels. Dont worry about the wait to start. its going to delay the start anyway. mine is 7sec befor it cranks. if it dosnt start it will try again. only once has mine needed to crank a 2nd time. by that time the glow plugs will be warm. But if it has a delay featcher use it 20sec is good.
Old Oct 17, 2009 | 10:50 PM
njkite51's Avatar
njkite51
I have n 04 PSD with remote start and have never had a problem. It delays for about a minute before it kicks over. I have nver had a problem with it, i do not remember the brand but i'll look into it and let you know
Old Oct 18, 2009 | 08:55 AM
jdadamsjr's Avatar
jdadamsjr
Hve the oem Gold remote start...
it is aftermarket,installed by a third party on mine...
has worked super for 5 years....
MY only complaint - wish I had gone aftermarket and gotten the two way key fob so it would acknowledge when the truck got the signal.... if the signal gets to the truck, it starts - every time.... I just never know if I am out of range or not and have to wait until I see or her the truck start....
Having a remote go out a half mile is no good if you are uncertain if it started or not
neighbor has the lil led that shows a smoking vehicle when it starts - too cute !
