What size engine stand
Old Oct 14, 2009 | 01:31 PM
texans's Avatar
texans
Pulling motor how much does it weigh. And what size stand do I need to get
Old Oct 14, 2009 | 02:27 PM
69cj's Avatar
69cj
I had a 1,000 lb. engine stand fail on me last year with a 428 cj motor on it so I would not use anything under a 2,000 lb. stand. Cost me a new pan and several pulleys. Almost my left arm.
Old Oct 14, 2009 | 02:31 PM
freeride808's Avatar
freeride808
The motor loaded is 900lbs or so. I used a 2000 lb stand and it was touch and go at times.
Old Oct 14, 2009 | 04:51 PM
69cj's Avatar
69cj
I do sometimes wonder who or what standard they use for rating these stands. There is definitely no fudge factor built into them. I can just about guarrantee that.
Old Oct 14, 2009 | 06:59 PM
liv's Avatar
liv
Its suprising too. Considering I've had a lot of weight on crappy 1k pound jack stands. Hydraulic pumps usually can't take anywhere near what they are rated for though. Considering how many 3-5k lb floor jacks I've destroyed with trucks.
What are you doing to the motor!?!? I wana play.
Old Oct 14, 2009 | 07:15 PM
69cj's Avatar
69cj
Are you talking to me. If you are just restored a 69 mach 1 with 428 cj. came out awesome
Old Oct 14, 2009 | 07:24 PM
texans's Avatar
texans
Come on down to Texas I'll buy the beer. I burned up a piston(I think). So I found a motor with 30,000 miles on it and I'm going to stud it and all sorts of good stuff before reinstalling it. Then I'm going to start rebuilding the one I'm pulling out. I hope the block is not bad. We will see.
Old Oct 14, 2009 | 11:00 PM
liv's Avatar
liv
Originally Posted by 69cj
[/color]
I don't care about some old gasser I think I remember reading about your car last year. Love the mach's
I wish. I just took a 2 week vacation (well I'm still on it till monday) to make up for the fact that I'm not going to have a single day off until March 1st. I've got a project in store for the spring though that involves doing basically the same thing so make sure you take lots of pictures of the tear down and build. I need to see what I'm in for
Old Oct 14, 2009 | 11:09 PM
bismic's Avatar
bismic
Not sure if these will help any, but you might look them over:
<TABLE style="WIDTH: 327pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=436 x:str><COLGROUP><COL style="WIDTH: 327pt; mso-width-source: userset; mso-width-alt: 15945" width=436><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 327pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=436>http://turbodieselforums.com/downloads/6.0L%20engine%20stand.pdf</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 327pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=436 x:str><COLGROUP><COL style="WIDTH: 327pt; mso-width-source: userset; mso-width-alt: 15945" width=436><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 327pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=436>http://turbodieselforums.com/downloads/6.0L%20Removel%20Tips.pdf</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 327pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=436 x:str><COLGROUP><COL style="WIDTH: 327pt; mso-width-source: userset; mso-width-alt: 15945" width=436><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 327pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=436>http://turbodieselforums.com/downloads/6.0L%20Head%20Service%20Tips.pdf</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 327pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=436 x:str><COLGROUP><COL style="WIDTH: 327pt; mso-width-source: userset; mso-width-alt: 15945" width=436><TBODY><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 327pt; HEIGHT: 25.5pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=436>mms://multimedia.ford.com/seopts/wsm/cylinderheadflatness.wmv
<TABLE style="WIDTH: 327pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=436 x:str><COLGROUP><COL style="WIDTH: 327pt; mso-width-source: userset; mso-width-alt: 15945" width=436><TBODY><TR style="HEIGHT: 113.25pt; mso-height-source: userset" height=151><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 327pt; HEIGHT: 113.25pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=151 width=436>mms://multimedia.ford.com/seopts/Tech4_250k.wmv</TD></TR></TBODY></TABLE>
Old Oct 15, 2009 | 09:03 AM
texans's Avatar
texans
Thanks mark I can always count on you to give some awesome links. You must be a wiz
at google.
Old Oct 15, 2009 | 11:01 AM
liv's Avatar
liv
He's a robot. All that information is stored in it's "brain"
GuitarJesus
Sep 27, 2016 12:18 AM
Jesser02EX
May 14, 2016 11:26 AM
ChiefM
37
Jul 19, 2015 08:13 AM
Rat77
Sep 6, 2013 07:48 PM
74highboy
Feb 14, 2010 08:17 PM
