Floor jacks!
Old Aug 31, 2013 | 06:39 PM
Rat77's Avatar
Rat77
Floor jacks!
My 2002 Ex 4x4 developed a shudder during breaking. Today while trying to jack it up and put on jack stands. My 2 3/4 ton jack was too weak/short to lift it up to put on stands. I am using 6 ton stands just to lift the front.
So have to get new jack. Keep in mind I don't have a ton of cash for new jack. What size are you all using to get your ex up on stands? Thanks
Old Aug 31, 2013 | 06:53 PM
SG1NUT's Avatar
SG1NUT
Bottle jack.
GM Performance 6 ton Bottle Jack - Tools - Mechanics & Auto Tools - Lift Equipment & Jacks
Old Aug 31, 2013 | 07:22 PM
acf6's Avatar
acf6
I use a craftsman 3 ton floor jack, it lifts my 6.0 fine
Old Aug 31, 2013 | 08:19 PM
EXv10's Avatar
EXv10
Me too, sometimes I put a tree cut-off (round) under it or a 4x4" block. I see them and heavier ones all the time at garage sales for $5 with handles and working fine. I also run it up on those portable ramps sometimes (another 5-$10 item) but they need to be heavy enough. I have flattened 2 sets of them so far at a total loss of $10. The ones I have now are wider in the mid section than the others ($10). If the truck can make it up to the top they will stay in proper form.
Old Aug 31, 2013 | 08:23 PM
acf6's Avatar
acf6
Yea if i need to lift high i just crib 4x4s under it. I also need to start doing that because our driveway is old and my truck actually pushed the wheels of the jack into the driveway...
Old Aug 31, 2013 | 08:34 PM
ycis's Avatar
ycis
I thought everyone owned that large 6ton blue floor jack from sears...
Old Aug 31, 2013 | 09:04 PM
59CRL's Avatar
59CRL
I second the bottle jack. I have a 20 ton.
Old Aug 31, 2013 | 10:11 PM
Rat77's Avatar
Rat77
12 Ton Air Hydraulic Bottle Jack
This looked like it might do the job. Anyone tried it?
Old Aug 31, 2013 | 10:27 PM
AndrewWV's Avatar
AndrewWV
I just used this one.
GM Performance 3 ton SUV High Lift Jack - Tools - Mechanics & Auto Tools - Lift Equipment & Jacks
Nothing great, but it did the job. I have a set of these to go with it.
Torin Double-Locking Ratchet Action Jack Stands — 6-Ton Capacity, Model# T46002A | Jack Stands| Northern Tool + Equipment
Old Aug 31, 2013 | 10:29 PM
RBlac's Avatar
RBlac
The bottle jacks make me nervous. I like the creeper style, wider base, wider jacking plate etc. I don't sweat jacking up both tires at the same time with the creeper style, would never attempt w/ bottle jack. Just IMHO. They do have there place, smaller and definitely sturdy enough.
Old Aug 31, 2013 | 10:36 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
3 ton floor jack here. I like how they have the 4" or so square perch to ensure a good lift point
bottle jacks scare the bejesus out of me. I had one slip off the axle on my Bronco. they are dangerous and I only use them as a last resort
Old Aug 31, 2013 | 11:04 PM
EXv10's Avatar
EXv10
Bottle jacks are good to save space in your garage and safe if you place them correctly and only lift one wheel at a time. As with any jack they need to be used with a stand(s) if you are going to crawl under there. I had one slip many years ago when a friend was under the car checking out a muffler. It put a little squeeze on him and gave him a lifetime memory. We quickly re-positioned the jack and pulled him out by his legs.
Old Aug 31, 2013 | 11:34 PM
MURDOMINO's Avatar
MURDOMINO
when my old 6 ton floor jack finally gave up the ghost, i bought a pair of these...
3 ton Heavy Duty Floor Jack with Rapid Pump®
They go on sale constantly, check in any automotive magazine for the HF coupons, and they go for 79.99 and are a hell of a deal compared to used stuff on the market. have a set of four 6-ton older jack stands that work great to support the frame when the truck is jacked up by the axles.
Old Sep 1, 2013 | 01:56 AM
RBlac's Avatar
RBlac
Thank you-Floor jack was the term I was looking for. Creeper jack...
You-all knew what I meant though.
Old Sep 1, 2013 | 02:13 AM
housedad's Avatar
housedad
I guess I'm a bit crazy about this.
(2) 3-1/2 ton floor jacks, one Michelin, and the other a Sears. (4) 20 ton bottle jacks, and I almost forgot: a long chassis floor jack I got used a few years ago from a gas station going out of business. It lifts about 28 inches. Heavy as sin.
4 each of 3 ton, 6 ton, and 12 ton jack stands, and a bunch of 6X6 for cribbing when I lift all four wheels. I use the cribbing for safety, not to hold the load.
And don't forget the chocks. 4 large plastic, 4 large rubber, and 4 small rubber.
I'm paranoid about it for a reason. Having a car fall on you is not pleasant and if you don't die outright then it hurts scary as hell while your ribs break slowly and you can't breath anymore.. (You don't want to know how stupid I was when I was young)
I got a bunch of logs, too. I should keep them in mind for it.
Someday I should invest in a asymmetric lift. That would be a lot better.
