Sponsored by: Real Truck
Having Problems with Climate Control
Old Mar 31, 2011 | 07:35 AM
BlackstarF250's Avatar
BlackstarF250
Trailering
Hi all.
I have a 2007 F250 Lariat. I've been having problems with my climate control for the last 6 months or so.
My External temperature on my the climate control display has been showing the wrong temperature. At first it was only off once in a while and only by a few degrees. Now its way off. When its 40 F outside, the display is showing anywhere from 60 to 103. So now when I set the temp on the controls to say 72 and the display is showing Ext at 90, its causing the temperature control to vent the outside air into the cab rather than turn on the heat.
I've had it to a mechanic a couple of times. The temperature sensor in the grill has been changed with no improvement.
Where do I look next?
Old Apr 2, 2011 | 10:25 AM
KREECH's Avatar
KREECH
I've got the same problem with my 08 F250 but going the opposite direction. It's 90 degrees outside, and I watch the A/C turn off when the exterior temp drops to -32. Not comfortable.
The dealer replaced both actuators for driver/passenger because at first it blew hot on one side and cold on the other. 5K miles later, I have this new problem. I'm going to get the truck flashed in the next two weeks. See if that helps.
Old Apr 2, 2011 | 11:13 AM
HillHunter's Avatar
HillHunter
I had this problem with a 06 F-150 and the dealer never could fixed it. So I got rid of it for a F-250.
Old Apr 2, 2011 | 03:47 PM
wiingnut's Avatar
wiingnut
Usually the external sensor is the issue. At this point I would try to locate a chaffed wire.
RamblinAnne
Apr 22, 2019 05:43 PM
SS70ElCaminoOwner
Mar 6, 2016 12:52 PM
dwh039
Jul 5, 2015 12:46 PM
cdnalpina
Sep 22, 2014 04:43 PM
jd350b
Jan 17, 2014 10:27 AM
