IPR Removal
Old Oct 14, 2009 | 04:41 PM
cowmilker08's Avatar
cowmilker08
Originally Posted by Vinford
I welded a flat piece of bar across the end of my socket.
I didnt remove my fuel bowl and Ive done it about 4 times and going to do it again about tomorrow.
I put my socket on and can then get something over the welded bar and loosen it.
Then I crammed my hand in there (tight fit) but it was finger out then.
Reverse procedure going back in.
I can change it in just a couple of minutes now.
Why do you have to do it so much?
Originally Posted by RÖENTGEEP
I think if you put a clear hose in the IPR as recomended with the GPs, it would be easy to take it out, dont you think?.
Can you explain that one to me?
Old Oct 14, 2009 | 04:48 PM
Talyn's Avatar
Talyn
Slip the hose over the end and use it to turn it. Since the hose is flexable. it easy to turn.
Old Oct 14, 2009 | 04:50 PM
cowmilker08
what hose?
Old Oct 14, 2009 | 06:39 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Originally Posted by cowmilker08
what hose?
Talyn is right. the hose is one that you buy or you have in the shelf, for water, gas or anything and you cut a piece of that and do what Talyn wrote.
Old Oct 14, 2009 | 08:03 PM
cowmilker08
I'm assuming that this is after you've loosened it with the stupid tool. I was thinking I should still take the bowl out because my fuel lines in the V look absolutely horrible. Where can I get new one's? Would a hardware store have hose that is safe for diesel fuel? Or maybe I could make the switch to electric fuel! Too bad its probably outside my current truck fund.
Old Oct 14, 2009 | 08:58 PM
Talyn's Avatar
Talyn
I replaced everything but the blue ones with standard braided fuel line.
Old Oct 14, 2009 | 09:06 PM
cowmilker08
i'm talking about the blue ones.
Old Oct 14, 2009 | 10:41 PM
brooksbronco17's Avatar
brooksbronco17
I used 3/8" fuel injection hose from napa. Had blue rubber inside covered in black rubber. was rated for diesel and can handle 300 psi. Was a little more expensive but you don't need more than a foot of it.
Brooks
Old Oct 14, 2009 | 11:06 PM
cowmilker08
Thank you, And just so you guys know, a) I spend too much time here apparently because I took the two study quizzes for my multivariate calculus class and only got 5/10 and 4/10. I have never missed class and the mid-term is at 10:30 in the morning and b) I plan on finally getting this project wrapped up on friday morning when it is supposed to be snowing. Got to go cram-study now.
Old Oct 14, 2009 | 11:36 PM
Talyn's Avatar
Talyn
Already has snowed here.
Old Oct 15, 2009 | 07:41 AM
cowmilker08
snow came a day early, I still have 5 projects to do before winter.
Old Oct 15, 2009 | 10:50 AM
Talyn's Avatar
Talyn
5? thats all?
Old Oct 16, 2009 | 07:24 AM
  #28
cowmilker08
Well actually six now that i think about it, unless you count upgrades. Then the truck will be in perfect condition other than the body.
bismic
Mar 9, 2022 09:20 AM
ten.mile
May 16, 2020 04:34 PM
pbruckne
6.7L Power Stroke Diesel
17
Jan 5, 2020 07:45 AM
nashaj
Sep 5, 2017 07:09 PM
06FUN
Oct 29, 2016 07:53 AM
