Engine Failure Survey
Old Oct 31, 2009 | 12:24 AM
  #46
Bigcat350's Avatar
Bigcat350
Originally Posted by Orezona
How did you like the 175/146 stick on the stock turbo and how was it modded?
Jason I liked the 175/146 injectors they where a nice upgrade from stock. I had the stock turbo and DP tunes and could pop 30 boost. I know you can tune yours now so you could probably tweak it in even better. I also got a little better MPG with them.
Old Oct 31, 2009 | 12:28 AM
  #47
Orezona's Avatar
Orezona
I can't tune mine I can just burn what Bill sends me. Was your stock turbo modded at all and did you tow? Stock IC right?
Old Oct 31, 2009 | 12:36 AM
  #48
Bigcat350's Avatar
Bigcat350
Stock turbo not even a WW. Yes I tow a lot. But not the grades or mountains some of you do. Stock IC at that time. I did like the 175/146 sticks. I just want a little more!!!
Old Oct 31, 2009 | 12:37 AM
  #49
Orezona's Avatar
Orezona
Thanks for the input.
Old Nov 9, 2009 | 10:16 PM
  #50
Groovy Chick's Avatar
Groovy Chick
Former Vendor
Originally Posted by DP-Tuner
https://www.ford-trucks.com/forums/8...-from-php.html
It’s great that you have designed this analyzer. Technology is so cool! It’s a step in the right direction for finding out what we attempted 2 years ago with Dennis’s engine failure survey. We would like to add, if all parties are willing, any of our chips questioned for accuracy to also be tested with our Engine Analysis Equipment. This will give 2 data points, one mathematical and one physical analysis. At that time we can compare the processes to make sure we are testing the same data points to obtain the data accurately.
We feel by offering our test equipment to the research it will complement the analyzer data due to the analyzer only seeing what points are inputted and the EA equipment pulling data that is induced.
We hope that this will encourage other companies that use special testing equipment to create and test their programming to also join in this analysis.
Jody
Jody, as I told you on another forum, I think it's great that you'll offer this service to your customers. We encourage any customers with concerns about their calibrations to discuss their Analytune™ results with their tuners. If any DP customers who come to us to have their tunes analyzed for SOI, ICP, and IPW have concerns, you can provide them with your Engine Analysis Equipment testing results. That, of course, is up to the customer and has nothing to do with PHP. If you list this service on your website, you may want to mention that so there is no confusion.
Old Nov 18, 2009 | 08:03 PM
  #51
Groovy Chick
Former Vendor
From Bill:
Just an update ...
Since returning from SEMA, Corey and I have both been out with the Flu. I'm back on my feet but Corey seems to have progressed into pneumonia. This has delayed releasing the results of the survey since I simply haven't had the time to compile the data.
I will be getting everything together this weekend and will be providing our findings with the affected vendors before releasing the data. Hopefully the data will provide insight and open up discussion as to where the problems lie and how we all can avoid failures in the future.
One thing I will say is that SOI (timing) clearly plays a crucial role in most of the failures. We been able to not only run calibrations through the AnalyTune software but now have the ability to live datalog the SOI values in the <acronym title="Powertrain Control Module">PCM</acronym> and have seen SOI curves approaching 60 degrees in an actual running situation. Combine that with modified injectors and you significantly increase the chance for disaster. When you consider that the stock <acronym title="Powertrain Control Module">PCM</acronym> is only running about 20-22 degrees of timing, there is no question as to what may be the most significant contributing factor in most (if not all) of the related engine failures.
Again, I am sorry for the delay in getting the information ready and really do appreciate everyone's involvement and contributions.
Please know that we are leaving the survey open indefinitely at this point. If you would like to participate, you're welcome -- and encouraged! -- to do so!
Take care.
Old Nov 18, 2009 | 08:46 PM
  #52
Tenn01PSD350's Avatar
Tenn01PSD350
Looking forward to it Corey. Hope Bill gets better soon. I will be in touch with you folks in the near future about another matter.
Old Nov 19, 2009 | 10:22 AM
  #53
PaysonPSD's Avatar
PaysonPSD
Get well soon Bill.
Thanks for this update Corey.
Old Nov 19, 2009 | 11:37 AM
  #54
Groovy Chick
Former Vendor
We're looking forward to being able to help you.
Originally Posted by PaysonPSD
Get well soon Bill.
You're very welcome!
Old Nov 22, 2009 | 08:44 AM
  #55
Kwikkordead's Avatar
Kwikkordead
Originally Posted by Groovy Chick
From Bill:
One thing I will say is that SOI (timing) clearly plays a crucial role in most of the failures. We been able to not only run calibrations through the AnalyTune software but now have the ability to live datalog the SOI values in the <ACRONYM title="Powertrain Control Module">PCM</ACRONYM> and have seen SOI curves approaching 60 degrees in an actual running situation. Combine that with modified injectors and you significantly increase the chance for disaster. When you consider that the stock <ACRONYM title="Powertrain Control Module">PCM</ACRONYM> is only running about 20-22 degrees of timing, there is no question as to what may be the most significant contributing factor in most (if not all) of the related engine failures.
Definately will cause some damage!
Thanks for the update and get well soon.
Old Nov 23, 2009 | 09:27 PM
  #56
Tenn01PSD350
Still awaiting the data from this study.
Old Nov 24, 2009 | 12:44 AM
  #57
BDalton's Avatar
BDalton
Subscribing
Old Dec 3, 2009 | 07:29 PM
  #58
Groovy Chick
Former Vendor
Just wanted to let everyone know that we are compiling the information gathered from the Engine Failure Survey now that that I'm back in the office.
We are in the process of contacting the tuners listed on the survey to find out the number of tunes they have in service so that this information can be part of the final data.
We are also contacting survey takers by e-mail to ask them two additional -- very pertinent! -- questions that we realized should have been included.
for your patience!
We will leave this survey open until the data is posted so that anyone else who has experienced an engine failure can add his/her information!
The survey can be accessed HERE.
candy2usc
General Automotive Discussion
28
Oct 22, 2010 11:36 PM
candy2usc
New Member Introductions
Sep 16, 2010 01:13 PM
ak_907
23
Mar 2, 2010 12:38 PM
Groovy Chick
16
Dec 3, 2009 07:30 PM
megawatt00
20
Sep 26, 2008 10:44 PM
