motor mounts
Old Oct 12, 2009 | 01:51 AM
1oldtimer's Avatar
1oldtimer
motor mounts
Has anyone used the mounts from trans dapt or similar ones. These are bolt in side mounts that use a biscuit style mount, in the repo parts books all i've seen are the full crosmembers.......all I can think of is the full crossmember helps with frame rail twist (from sitting weight of motor).
Old Oct 12, 2009 | 09:54 AM
Julies Cool F1's Avatar
Julies Cool F1
I haven't, but I'll bump this back up for ya....good luck!
Old Oct 12, 2009 | 11:37 AM
Old F1's Avatar
Old F1
................…or from engine torque?
This is a little weird (and cool), a (old) guy from the “Hot Roding Capital” of the world talkin’ with a (old) guy from “Resume Speed” nowhere!
I think that the cross-member type motor mount and (if you have a) mustang II cross-member do not always make for a happy couple with both trying to occupy the same space at the same time and therefore the frame mounted engine mounts, but of course in that situation the M II cross-member would provide extra strength.
There are some nice frame engine mounts available or you can build your own.
Old Oct 12, 2009 | 08:40 PM
1oldtimer's Avatar
1oldtimer
that's what the internet should be about .
it has a homemade fe crossmember in it now (and i stress homemade ) and i'm not sure if i'm going to stay with the 390. i've already bent the brake lines and they might be in the way of a new crossmember. the ones i was talking about are the black ones pictured above.
Old Oct 12, 2009 | 10:00 PM
Old F1's Avatar
Old F1
[QUOTE=1oldtimer;8028442]i'm not sure if i'm going to stay with the 390./QUOTE]
Don’t let Julie hear you say that!
What about a new FE cross-member?
Old Oct 12, 2009 | 10:40 PM
1oldtimer's Avatar
1oldtimer
the 390 needs to be rebuilt (and the C-6 might not be too far behind, found a piece of a large snap ring in the pan). as much as i hate to think about it, this is going to be a daily driver so mpg is going to be a factor. so with the 10-12 mpg and the $3000-$3500 for a quality rebuild i'm thinking of a change.
Haroldmac
29
Jan 3, 2013 07:46 AM
rodriguezfords
Oct 26, 2012 04:59 PM
buckshot362
Oct 18, 2008 01:34 AM
sdunham
1978 - 1996 Big Bronco
13
Nov 23, 2005 12:17 AM
