Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Need to replace 460'd 89 Bronco motor mounts..?
Old 02-28-2005, 09:43 AM
sdunham
sdunham is offline
sdunham is starting off with a positive reputation.
My 89 Bronco has a 96 460 with L&L motor mounts which have failed again for the 2nd time in 2 years. The rubber seperated from the metal plate and when it did, the motor jumped, took out the remote oil filter line and I lost all oil in about 20 seconds... Never again... I'm looking at Advance Adapters ( Autofab ) comp style mounts but they require removing the stock frame mounts from the frame... Anyone ever used these and how much of a PITA is it to swap to these with the engine still in ...?
Old 02-28-2005, 10:02 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
have you contacted L&L about this. i would be screamin at em. you should have them pay you back for there faulty mounts and for your remote filter setup.
someone may chim in on this im sure
later
Old 02-28-2005, 10:32 AM
sdunham
sdunham is offline
Yeah, I talked to them about it. Needless to say, I'm not interested in persuing them for a fix as their product just doesn't work for long... Both of their mounts failed in the exact same way so I'm done with them... I don't have time to get into a p*ssing match with them...
Old 02-28-2005, 11:36 AM
Gurahl
Gurahl is offline
Gurahl is starting off with a positive reputation.
If you don't mind me asking, what vehicle did you get the 96 460 from and how difficult was the swap?. I am wanting to have mine converted over after I get back from Iraq, but was trying to avoid an older motor. Thank you for any and all help.
Gurahl and his "Bronc'enstein"
Old 02-28-2005, 12:25 PM
sdunham
sdunham is offline
Got mine from Leanard VahSHoltz of Pikes Peak Hillclimber fame. He's sponsored by FORD and got a bunch of motors/trannies after they were pulled off the assembly line when the truck they were intended for was pulled for quality inspection... Mine came from a 1996 F350 and had the E4OD tranny bolted to it ... Physical swap was pretty straightforward using stock BW 13-56 t-case, new radiator, L&L Motor mounts, fabbed tranny shift linkage, new driveshafts, remote oil filter... Toughest part was converting 89's firewall harness to 96 engine/tranny harness... Used HELM schematics for both years and spent alot of time splicing things together at the firewall... Also had to buy 96 460 PCM...
Old 05-25-2005, 03:58 PM
bigwhtbco
bigwhtbco is offline
bigwhtbco is starting off with a positive reputation.
what front springs are you running, i have an 89 also and i lost about an inch of lift with the 460. stock it had 302 springs
Old 05-25-2005, 03:59 PM
Kemicalburns
you can run 2wd f250 springs up front. unless you have a lift of course
Old 05-26-2005, 06:39 AM
Steve_Uzi
Steve_Uzi is offline
Steve_Uzi is starting off with a positive reputation.
Why are the Motor Mounts failing? Is oil dripping onto them? I know that oil loves to eat rubber mounts over time for sure...
I use the L&L Mounts in my 460 powered Bronco and they are Great! No problems and that is even after a few dozen childish Brake stands to smoke nearly junk 32x11.50 tires.... (my buddy works at a tire shop so I often get tires to do smoke shows with.... Immature I know but its fun... even if I am 37 )
Also use F-150 extended cab heavy duty springs in your Bronco. I did that in my 84 when I put my 460 into my Bronco. Those springs have the same install height as the springs for the Bronco's but they have 400 lb more load capacity. Those HD F-150 springs may be the same as Standard F-250 springs.. Most Good parts shops have Coil Spring books with provide all the details about each coil spring listed in their catalog...
Old 05-26-2005, 09:10 PM
bigwhtbco
thanks guys, greatly appricialted. i do have a mild lift, so i am thinking of calling rancho and getting 2 inch lift springs for an f250
Old 05-26-2005, 09:11 PM
bigwhtbco
ohh, by the way, i also, am on my second pair of l and l motor mounts. both of mine completly seperated. so maybe some just arnt made as well.
Old 05-26-2005, 11:39 PM
Steve_Uzi
Did L&L replace the Mounts for FREE?? That is the question!
Old 11-22-2005, 12:43 PM
bigwhtbco
yes, they did replace the mounts for free. but the just broke on me again. right now i'm running a chain, not a very good idea but i need to drive, and i made up a set of mounts myself that i have to install. they are solid but i am squeezing 3 pieces of conveyer belt rubber between the frame and the mounts. hopefully my welding will hole of better then L&L's fabrication.
Old 11-22-2005, 01:13 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
here is a link to another place that builds a direct bolt on swap motor mount for this application, there is a guy running a bronco with a 598 stroker in a drag racing that is pulling mid 10s in the quarter using these motor mounts and isn't breaking them so they must be tougher than the L&L stuff (and he said he originally had L&L, and had the same problems with failing) if that doesn't work I went to solid mounts but you probably dont' want to do that in a street driven vehicle but if you do I can probably get you a phone number of the guy that built mine just PM me (I don't want to put someone elses phone number on an open board)
anyway here is the other place.
click here
it will give you the FTE page about supporting sponser but there is a link that says to go to the site you clicked on click here, and it will take you too it.
Old 11-23-2005, 12:17 AM
steveg3
steveg3 is offline
steveg3 is starting off with a positive reputation.
I've used Autofab mounts in a couple trucks and have been extremely happy. They are built well with hard abuse in mind.
chrome_eagle
10-07-2012 08:16 AM
torinotalladaga
08-25-2009 08:22 AM
jnyreb69
03-15-2009 10:43 PM
79-400-POWER
10-17-2007 07:46 PM
oldmansimek
12-25-2006 11:50 AM
Quick Reply: Need to replace 460'd 89 Bronco motor mounts..?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
