Trans maint. question
Old Oct 11, 2009 | 06:41 PM
abah's Avatar
abah
My 06 4.6l f150 just hit 50,000 miles and I have kept up with most of the maintenance pretty well. Would anyone recommend I go ahead and flush my trans out as well? Ive called two different dealerships to get quotes, one told me to go ahead and get it done, the other one told me to wait until it hits 60k.wtf. Ive done some heavy towing but over short distances only. Ive also noticed a whine in my trans. whenever 3rd gear engages. what would you guys say?
Old Oct 11, 2009 | 07:07 PM
shorebird's Avatar
shorebird
I personally would have done a flush at 30K. Filter and flush at 60K. Do you have a 4R100? Fluid service required every 30K for the 4R100.
Old Oct 11, 2009 | 07:10 PM
hcbph's Avatar
hcbph
Maint
To me, my feeling is when in doubt, do it. I do things like oil changes early based on requirements, but I think it pays off in the long run.
Old Oct 11, 2009 | 08:53 PM
whimsey's Avatar
whimsey
I'd go with a complete fluid EXCHANGE. Flushes often involve adding "cleansing" chemicals. These can and have caused tranny problems sometimes. EXCHANGING is a gentle way of replacing all the tranny fluid with fresh fluid. If the old fluid had lots of miles on it I'd do 2 fluid exchanges. The second one maybe 10,000 miles after the first. Then go on a 30,000 mile fluid exchange. At least for the first exchange change the filter and refill the pan then do the exchange. Most likely you can do this every other ATF exchange unless you are getting lots of debris in the fluid.
Whimsey
Old Oct 12, 2009 | 09:21 AM
abah's Avatar
abah
Thanks for the input. I found out I have the 4R70E trans. Ford dealership recommended flushing it out, dropping the pan, replacing filter, adding new fluid for $175 plus the cost of a new filter. Does it even need all this done or just a simple fluid exchange like you guys said? Im **** about this, want to keep her running long time. Thnkas for the input
Old Oct 12, 2009 | 08:08 PM
FORD COASTIE's Avatar
FORD COASTIE
Veteran: Coast Guard
I would have them drop the pan and change the filter if I were you. 50,000 is a lot of mileage on that fluid. I have mine done every 30,000 miles.
fordka
16
Jun 7, 2014 07:21 PM
SMiddleton
1983 - 2012 Ranger & B-Series
Apr 9, 2012 04:30 PM
89LX306
Jun 13, 2011 01:16 PM
NewRed
Feb 18, 2009 09:34 PM
dsmith1484
Apr 14, 2004 11:49 PM
