Auto to 5spd
Old May 13, 2014 | 11:00 PM
fordka's Avatar
fordka
Auto to 5spd
Im swapping to 5spd in my 94 f250 idi. Does the trans crossmember have to be changed or just moved ahead. A bunch of ppl tell me i need a 5spd one and another person told me i just need to move the auto one ahead and the wholes are already in the frame. Can anyone shed light on this
Old May 14, 2014 | 11:46 AM
fordka's Avatar
fordka
Does anyone know i need to find out thanks
Old May 14, 2014 | 12:15 PM
cman1120's Avatar
cman1120
I too plan to undertake this swap at some point and everything I've found indicates the crossmember must be replaced with a 5 spd one. Youll need the pedal assembly flywheel, clutch, the tranny (obviously lol) and also the manual steering column cover and plate to cover the gear indicators on the cluster. You don't need them per se but it does make it look much nicer and factory imo. I'm sure someone with more knowledge will be along later to assist.
Old May 14, 2014 | 03:06 PM
fordka's Avatar
fordka
Yup haha i found a bunch of stuff just waiting on a shipping qote. But the guy i was talking too said he has done swaps before and used the same cross member but moved it ahead. I do know the standard ones do curve forward.
Old May 14, 2014 | 08:40 PM
jerryparks's Avatar
jerryparks
don't forget sawing a hole in the floor... important little details.
Old May 14, 2014 | 09:03 PM
fordka's Avatar
fordka
Already got a tunnel cover located. Another thing. Will i need a starter for a manual trans
Old Jun 5, 2014 | 08:35 PM
jerryparks's Avatar
jerryparks
I believe (I do not know for sure, don't quote me on this) that it's just a different Neutral safety switch that is connected to the clutch pedal.
Old Jun 5, 2014 | 08:40 PM
Diesel_Brad's Avatar
Diesel_Brad
YES, different crossmember
And different driveshafts
Old Jun 5, 2014 | 10:13 PM
fordka's Avatar
fordka
Originally Posted by Diesel_Brad
YES, different crossmember And different driveshafts
Is there already holes in the frame for it and will one from a f150 with mazda trans work for it. Also do you happen to know what length drive shafts i need.
Old Jun 5, 2014 | 10:22 PM
drjoe171's Avatar
drjoe171
Partway through a major swap, I ran across a
wrecked truck (blown engine) with ALL the parts I needed.
Cheaper than hunting parts.
I'll keep my fingers crossed that what you need
magically appears.
Old Jun 6, 2014 | 04:34 AM
Diesel_Brad
Holes are there.
Mazda crossmember is different
I don't know the exact measurements, But the front will need to be shorter and the rear longer
Old Jun 6, 2014 | 08:36 AM
fordka's Avatar
fordka
Do you know if anything off a f150 with the mazda will fit such as the pedals steering column or tunnel cover. Or can the cross member be from a small block zf.
Old Jun 7, 2014 | 04:28 AM
Diesel_Brad
Seriously? How much of a search DIDN'T you do?
Old Jun 7, 2014 | 08:56 AM
fordka's Avatar
fordka
Oh what. Ive been looking this up for 2 months. And have found hardly anything and when i ask ppl i never get a solid answer.
Old Jun 7, 2014 | 08:59 AM
fordka's Avatar
fordka
Btw i have done plenty of trying to look up what parts i can swap from a f150 with f250 and found no solid answers. Some ppl say yes others say no on certain parts.
