6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DTC code 2008 6.4L
Old Oct 11, 2009 | 12:19 PM
ktheavner's Avatar
ktheavner
Question DTC code 2008 6.4L
anyone know what P 2002-FF-PCM code is?
Old Oct 11, 2009 | 06:14 PM
senix's Avatar
senix
Here it is: P2002 REGEN Particulate Trap Efficiency
Below Threshold
This error occurs if an expected pressure drop through the DPF
is lower than the specified value following a regeneration cycle
(based on the concept of normalized pressure differential
Old Oct 11, 2009 | 08:11 PM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
Cai
Below Threshold
...and you can expect it with many (but not all) aftermarket cold air intakes. If you recently installed one, get used to it! If not, talk to your Ford dealer. I bought a Code Reader so I could just reset it whenever it happened.
Old Oct 11, 2009 | 08:18 PM
senix's Avatar
senix
I am running the banks and I have no codes, but some do as well as with others.
Old Oct 16, 2009 | 07:32 AM
ktheavner's Avatar
ktheavner
Thanks guys
I did install a S&B CAI system about 9 months ago and this is the first time it has happened but I was in the mountains when the re-gen took place maybe that was the problem.
Old Oct 16, 2009 | 07:37 AM
senix's Avatar
senix
Could be related since you have had it for 9 months. Did the S&B allow you to maintain the filter minder on it? If not might want to have a close look at the filter.
Old Oct 16, 2009 | 07:44 AM
ktheavner's Avatar
ktheavner
Yes filter minder still in place and filter is very clean. KT
i eat hybrids
May 20, 2017 10:15 PM
captinphill
1978 - 1996 Big Bronco
Dec 15, 2015 02:26 PM
kbf1961
Oct 17, 2015 10:05 PM
88 250
Dec 24, 2010 04:14 PM
Miketnf150
Aug 21, 2002 12:57 PM
