72 F100 ?s
would a 4 barrel carb hurt or help the motor. just had a rebuilt has less the 60000 miles on motor. when rebuilt was done.
what is the rearend size? and gearing?
thanks. sorry for all the ?s just got the truck and would really like to know history and specs of it.
To discover what you have:
Post the AXLE code found on the Warranty Plate, which is located on the left door face below the latch.
There are other codes on the Warranty Plate. Post all of them.
Myself or someone else can decode everything for you...including your VIN.
360: 145 net HP @ 4,000 RPM / Torque: 264 ft. lbs. @ 2,200 RPM.
390: 156 net HP @ 4,000 RPM / Torque: 292 ft. lbs. @ 2,000 RPM.
F10 = F100 2WD
Y = 360 2V
L = Michigan Truck Assembly Plant
P48716 = 1972
115" Wheelbase
COLOR 6 = Bright Medium Blue
BODY 2 4: 2 = Light Blue & Medium Blue Vinyl-Standard Cab // 4 = Styleside Pickup, Bench Seat.
TRANS C = Ford Type 3.03 3 Speed Manual all Syncromesh Tranmission.
AXLE 02 = Ford 9 inch Rear Axle / 3.00-1 / non Limited Slip / 3300 lbs. Rear Axle Capacity.
GVW = 4450 lbs. Gross Vehicle Weight Rating
157 NET HP @ 4,000 RPM / NET HP: At the rear wheels / Gross HP is measured at the flywheel.
DSO 23 = Memphis TN Ford District Sales (Zone) Office, where the original selling dealer ordered the truck from.
Title VIN?
Someone goofed
by typing a 4 (no such VIN engine code) instead of the Y.Don't like the net HP figures? Wait till you see the gross HP figures! It has everything to do with the new Fed Emissions Standards.
The HP race that began in the mid 1950's was just about over. The era of multi HP engines (and Muscle Cars) was coming to an end.
F10 = F100 2WD
Y = 360 2V
P48716 = 1972
115" Wheelbase
Title VIN?
Someone goofed
I have a 4 speed trans. and i found online hp was 215 and tq is 375. I must have a different motor and trans. then original, guess its a good and bad thing. good for what i want, bad for being restored original, which i planned on doing. hp rating must been underrated for insurance or something. my 5.7 camaro, has less *** then that truck. i also have red interior bench seat, limited slip rear. independent front suspension.
360: 145 [B
The NET HP is all that is listed on Warranty Plates thru 1972. After 1972, nothing is listed....at all.
Your truck's Warranty Plate lists: 157 NET HP @ 4,000 RPM for the 360 2V.
I do not have the GROSS HP figures for a 360. It was listed on the air cleaner decal as original, but I don't have a truck w/a 360 engine.
Here are the GROSS and NET HP figures for 1965/67 F100/350's w/a 352 2V: GROSS HP: 208 @ 4,000 RPM / NET HP: 172 @ 4,000 RPM.
Here's what the GROSS HP was for a 1971 390 2V as installed in a Galaxie/LTD: 225 HP @ 4,000 RPM.
In sales brochures, advertisements, and etc, auto manufacturers always list the GROSS HP figures.
But when the engines are dyno'd, the NET HP figures are known.
Here are some examples of late model pickups GROSS & NET HP figures from edmunds.com.
2004/2008 F150 Super Crew 5.4L (330 cid) 24 Valve SOHC V8 / GROSS HP: 300 / NET HP: 242.
2007/2008 Nissan Titan Crew Cab 5.6L (339 cid) 32 Valve DOHC V8 / GROSS HP: 317 / NET HP: 291.
During the HP race that began in the mid 1950's, automakers always OVER-estimated the GROSS HP figures, and the same thing is still being done today.
