How rare is a 72 F100 styleside, shortbed, 4spd. ?
My question is, I was told the motor was a 428ci. but how can i tell? it shows C8E4H Heads, 99352, which is on the front of the block. and a 45 ( I or one) F on the side by the oil filter. Is there any help, to tell me what it is?
I also have a lowering ?, the front coil springs were heated and ****ed up. there are no shocks in the rear. only leaf springs. how would i go about lowering the front and rear for a level stance, slightly tucked? and what size tires can i fit? fatter in the rear. like example: 275 and 225 in front.
428: 1966/70 Passenger Cars only.
What size engine is it? Measure the stroke: 428 = 3.98" / 390 = 3.78" / 360 = 3.50"
The head ID number is actually C8AE-H = Ford part number: C8AZ6049M. This head is nothing special.
You will need a 6-8in long piece of white house wire, a Sharpie, a friend and a big socket to fit the crank nut.
Remove the coil wire, one of the front spark plugs, poke the wire in the hole, rest the Sharpie on the manifold against the wire, have the friend turn the engine over a couple rounds by the crank, and measure the length of the mark on the wire.
Pretty Rare def a keeper
Does it have an externally balanced crank?
Thanks. For your help.
Inside the block behind the freeze plug on the drivers side rear there is a little 428 casting number in there. Just another way to tell ND would know all the tricks.
