6.9 Oil pressure
Old Oct 10, 2009 | 05:36 PM
smokey98's Avatar
smokey98
6.9 Oil pressure
Hello men, its been a while but my computer crashed and I have just been reading at work and not posting (is that bad?) So now I'm on my sons computer cause I have a question and I haven't been able to find a satisfying answer with the search option. So here goes.
Last week my water pump went out and that scared me into installing a temp gauge. I bought a three gauge set so yesterday I went ahead and put in the volt gauge and oil pressure gauge. While testing them the oil pressure will read 40psi at start up and while going down the road at highway speed but idle will be about 15psi. Does that sound ok?
When I searched for the answer people said up to 70psi cold idle and down to 5psi hot idle.
Thanks,
Long lost Joe
Old Oct 10, 2009 | 05:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Actually International will tell you hot idle oil pressure numbers lower than 5 PSI.
You sound like it is good to go with what you posted for numbers.
Old Oct 10, 2009 | 06:58 PM
smokey98's Avatar
smokey98
Thanks Dave, once again, your the goto idi guy.
Old Oct 10, 2009 | 09:47 PM
dyoungen's Avatar
dyoungen
I second that smokey, Dave is definetly the goto guy. Your oil pressures are almost exactly like mine. I did find out a few weeks ago when I changed my water pump and radiator, had a small leak, that on a long run it stays hotter but takes longer to warm up. Ford gages are just for guessing.
Old Oct 10, 2009 | 11:02 PM
JesterPgh's Avatar
JesterPgh
Dave definitely knows his stuff. Mine runs 30psi cold, 25 psi hot and above idle, 7 psi hot at idle.
Old Oct 11, 2009 | 04:37 AM
fonefiddy's Avatar
fonefiddy
Gotta remember, these are high volume oilers, not High Pressure.
oldmanbergie
Dec 9, 2010 12:06 PM
04F250PSD
Sep 8, 2010 01:22 PM
mike L
15
Nov 3, 2007 05:35 PM
mudslingur
May 23, 2007 08:48 PM
jimandmandy
Oil & Lubrication
Oct 7, 2003 11:46 AM
