Oil Pressure
Old Sep 7, 2010 | 03:47 PM
04F250PSD's Avatar
04F250PSD
Oil Pressure
I have a mechanical oil pressure gauge that I have tapped into the oil Filter cap. When I start the engine cold it will read around 90 psi and when warm around 60 psi, but when it is up to operating temp it will only read around 20 psi at idle and then back up to 60 if you give it any gas at all. My question is is this a good place to hook a mechanical oil pressure gauge to and if so are those reading correct?
Old Sep 7, 2010 | 04:57 PM
Benchwrench's Avatar
Benchwrench
Feed line mounted on top of the cap and being that erratic, chances are there is air compressing in the line giving you false readings.
Old Sep 8, 2010 | 01:22 PM
04F250PSD's Avatar
04F250PSD
I do not see any air in the line. Is the top of the oil filter cap a good place to read oil pressure and is the readings I am getting sound right?
FERacing66
13
Jun 1, 2020 05:16 PM
anthonym92
Apr 4, 2015 02:25 PM
betrayz
May 27, 2012 01:52 PM
danfish
Aug 4, 2011 10:05 AM
dneal00
Oct 4, 2008 05:32 PM
