1986 Ford van axle code identification
Old Oct 10, 2009 | 01:35 PM
hjcraver's Avatar
hjcraver
I found a 1986 Ford Van conversion in the Scrap yard with a 9" rearend. It has an axle code on the door of 16. Can anyone tell me what type (posi or open)and ratio it is. Should this be 31 spline axles? <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Oct 10, 2009 | 02:35 PM
85e150's Avatar
85e150
My '85 had 31s. Is there a tag on the studs holding the case into the housing? About 5 o'clock--lower part of the driver side?
Old Oct 10, 2009 | 03:17 PM
hjcraver's Avatar
hjcraver
code identification
This junkyard is around 15 miles away. The truck is on the ground with no wheels. I cant crawl under it unless I jack it up. I am allowed to jack it up if I buy the rearend. The door tag # is all I can get now. I appreciate any information you can find. Thanks Hubert
Old Oct 11, 2009 | 07:16 PM
subford's Avatar
subford
A 16 is a 3.50:1 ratio, 3750 lbs non locking Ford rear end.
Old Oct 12, 2009 | 04:55 AM
hjcraver's Avatar
hjcraver
Axle Identity
Thanks for your help. Hubert
sddesigns
New Jersey Chapter
Apr 20, 2010 06:58 PM
sddesigns
New Jersey Chapter
Apr 14, 2010 01:55 PM
THE BLUE HEAP
Dec 25, 2009 08:18 AM
Eddiestruck
May 5, 2009 04:18 AM
428HIGHBOY
15
Feb 17, 2009 07:02 PM
