Sponsored by: Auxito
can someone help me?
Old Oct 9, 2009 | 01:25 PM
TheProfessorofTOOL's Avatar
TheProfessorofTOOL
Question can someone help me?
Ok every time i turn on the heat in my f150 it has a very strong odor, when it is really cold it smells like urine, but when it is above 40 degrees it has a strong smell of coffee, i just wondered if that meant i needed to replace my heater core
Old Oct 9, 2009 | 01:50 PM
KhanTyranitar's Avatar
KhanTyranitar
mildew has taken up residence on your evaporator. Common problem especially in high humidity areas. You need to make sure the drain line from your evaporator is not plugged, if it is, clean it out. They make special products for killing and removing mildew for AC systems.
Old Oct 9, 2009 | 01:54 PM
TheProfessorofTOOL
ok i live in Tennessee so it is very humid here, but the ac doesnt hav a smell at all, just the heat, but how do i go about cleaning this tube. but when its hot outside and the ac is on in the truck it does drip water like every other car though
Old Oct 10, 2009 | 11:22 PM
ole_smokey_88's Avatar
ole_smokey_88
does your model have a cabin air filter ??
Old Oct 13, 2009 | 10:37 PM
TheProfessorofTOOL
no my truck does not have the cabin filter, i tried that option about 9 months ago to find out i dont hav one
rickpalmer
2009 - 2014 F150
Oct 10, 2014 08:56 AM
Str8shooter
6.7L Power Stroke Diesel
Oct 18, 2013 04:01 PM
Saxon
Dec 10, 2012 10:24 PM
aussie01
May 15, 2009 10:11 PM
Sanders
Feb 1, 2004 08:28 PM
