Sluggish!!!
Old Oct 8, 2009 | 12:25 PM
buckdaddy97's Avatar
buckdaddy97
Sluggish!!!
I have a 04 f250 with 6.0 diesel, if it sits for a few hours and gets cooled down, once u crank it back up it idles rough and will not respond to the accelerator once u put it into gear. But once u drive about a mile and a half to two miles it straightens up and runs fine. The temp outside hs been in the 80's so i wouldnt think its too cold. I plugged the truck in last night to see if it made a difference, and this morning i got in it and it ran like a top. This is my first diesel and i have only owned it a few weeks, so this is all new to me. Any ideas on what could be the problem?
Old Oct 8, 2009 | 06:24 PM
bismic's Avatar
bismic
Welcome to FTE buckdaddy97.
Your problems are fairly common - there have been a lot of threads recently on the same topic.
The issue can be as simple as injector stiction and a 5W40 oil along w/ the most recent computer flash (at dealership) could resolve.
or
You could have a bad injector or a bad fuel injection control module (FICM).
You could also just have an EGR valve that needs cleaning, but your symptoms do not exactly match that.
Have you had your computer software updated recently?
Are your batteries strong and healthy?
What oil do you use?
Are you meticulous on the oil and filter changes?
Old Oct 9, 2009 | 05:23 AM
buckdaddy97
Thanks for the reply, im not real sure about the oil thats in the truck like i said i just bought it a couple of weeks ago. I plan on changing the oil in it this weekend though, what oil do i need to put back in it? Where should i start on narrowing down my problem, changing the oil? Like i said this is my first diesel and im kinda lost on it.
Old Oct 9, 2009 | 06:40 AM
bismic's Avatar
bismic
How many miles on your truck?
The first things you need to do w/ a used vehicle (IMO), but a 6.0L especially:
1. Change the oil and filter. I would use a diesel rated (CJ4, CI4+) oil. The best oil for these trucks (again IMO) is a 5W40 synthetic. There are many choices - Rotella T or Mobil 1 are the most common choices. It takes 14 to 15 quarts. Do not fill it OVER the max mark on the dipstick. Use Motorcraft or International or Racor filters ONLY! You can get them from Walmart, International dealership, dieselfiltersonline.com and as a last choice (due to cost) the Ford dealership. The tech folder has instructions. Do not go more than 5k miles between oil changes even thogh the book says 7500 miles.
2. Change both fuel filters. The Tech folder has instructions. Again use ONLY Motocraft or International or Racor filters. Buy them from the International Dealership, dieselfiltersonline.com, or the Ford dealership.
3. Tranny flush AND external filter change. You have an external (bypass type) filter for your tranny. Instructions for changing it are in the Tech folder. You need a heated flush machine to get all the old fluid out. It has a thermostat in it and you can NOT drain the torque converter on these engines. The flush (or at least dropping the pan) should happen every 30k miles. Change the fuel filters NO LATER THAN 15k miles and I do them at 10k miles (every other oil change).
4. Change the air filter - you will have to go to the Ford dealership unless you order on line (dieselfiltersonline.com again). At least look at the filterminder and see if it indicates you need to change the filter. Do not try to "blow back" w/ air or re-use a known dirty air filter. It is not worth the risks.
5. Pull each battery individually and have them individually load checked. If they test fine, put them on a charger and when charged up fully, re-install.
6. Have an auto parts store test your alternator.
7. I would invest the $$'s and have the latest flash applied to the trucks computers. At that time, have them print you out an OASIS report - this will tell you every WARRANTY repair ever done on the vehicle. The updated flash will be around $100.
8. I would then pull the EGR valve and replace it - but I am a maintenance fanatic. Many folks just clean it. Either way, the instructions are in the Tech folder. These trucks are VERY finicky. The EGR system can cause a LOT of problems if you do not keep everything working properly. That is why so many folks delete the entire EGR system - especially the cooler. But that is for another time.
After all this, you may still need to replace some injectors, or replace the FICM - hard to say because troubleshooting the 6.0L problems can often be very hard.
EVERYTHING I HAVE MENTIONED HERE CAN AFFECT THE HARD STARTS (except the tranny servicing).
I have a thread at the bottom of the list of threads in the Tech Folder. It is titled something like "Tips to prevent common poblems w/ the 6.0L". You should read it over. Stay active on this foum .... what you learn here can save you a lot of money.
Old Oct 9, 2009 | 02:45 PM
'04Excursion6.0's Avatar
'04Excursion6.0
Had the same exact thing going on in my '04 Excursion. Had Ford do a flash update the other day and now it runs like a champ even when cold. Do you have a heat inductive flash update? If not I'd try this first, only $104 at my dealer.
Sweater61
Dec 24, 2014 11:47 PM
Redneckmorton
17
Feb 9, 2013 08:05 PM
DirtDiver52
Mar 14, 2012 07:41 AM
4inchlovin
N. California Chapter
15
Jun 22, 2009 11:43 AM
ajbeiler
Jun 23, 2007 02:47 PM
