E4OD manual valve body?
Did you know that you could have had the Audi 5000, with the manual five speed, could have come with such a high rear end, or call it a final drive ratio that only first and second were not overdrive, and third, fourth and fifth were all overdrive ratios.
A standard converter at freeway speeds will have such a reduced slippage as to be irrelevant.
And, even if a converter is slipping 5%, you can just choose gearing that is at least 5% higher or just install a slightly taller tire.
The converter in almost any auto trans locks up when the trans is in a higher gear and the vehicle is moving fast, meaning when there is little load across the converter - when you floor the throttle the converter usually unlocks too. And by the way, the E4OD converter when unlocked in OD and under heavy throttle gives you about the same overall gear ratio as when you're in 3rd and lock it - mine is on a manual switch so I've played with it a lot, at part-throttle you can actually use it as a gear splitter
And don't forget the matter of heat generation, a "standard" converter (what's standard about it?) will always make more heat than a lockup converter with its clutch engaged, that alone is a decent benefit I think. GV C6 6 forward speeds and 2 reverse gears.
E4OD 4 forward gears and 1 reverse gear that takes forever to get into.
Oh, an no need to be a *** to Mark Kovalsky, he has been of more help to us (at least to me) than you can ever be if your post that I quoted is any indication of your knowledge of the E4OD...
<br />
I once built a box that just controlled the shift solenoids. I was able to manually shift gears 1-2-3, and for that application I didn't need 4th. The problem was that I didn't have anything controlling pressure, I just left the VFS unplugged, which is max pressure. It worked fine for a short time and then the forward clutch drum came apart. It can't handle max pressure.
<br />
Mark, so the VFS works off current, and not voltage? Do you think it would be possible to use the TPS voltage change to control the current applied to the EPC solenoid through some sort of a variable resistor? In other words, the higher the voltage reading at the TPS, the lower the current to the VFS, resulting in a higher line pressure - much like the C6 operates with vacuum modulator, only our system will be electric.
Then build the pushbutton box for controlling the shift solenoids... Or, here is another thought, use the MLPS and the factory shifter - 1st position is 1st gear, 2nd is 2nd, OD position gets you 3rd reag, and you shift in and out of OD with a button much like the factory seyup. This way we still have the neutral, revers and park positions and gears operational. And since i mentioned it - reverse is full hydraulic application, correct, no solenoid action required to engage it?
I once built a system that used the MLPS to control the shift solenoids. I didn't need overdrive for that project so it only worked 1-2-3, but it worked. I didn't control EPC pressure, just left the solenoid disconnected which made max pressure all the time. It worked well until the forward clutch drum came apart. It didn't like max pressure.
Forums
www.MSefi.com • Index page
Archangel, that would possibly be a good thing for those adding a electronically-controlled transmissions to vehicles not previously equipped with such - I think I've seen you around the IDI diesel forum here, our fellow member there David85 from Canada would be a good example of that. However, what I'm really trying to do, is non-electronic manually-controlled E4OD - essentially an automatic that works like a manual trans, only without the darn clutch (I hate clutches more than I hate stuff that shifts on its own, lol). Basically I'm trying to eliminate any kinds of brains and PCMs and what not, just basic switches and relays and resistors and such.
And as for the shifting, the solenoids are activated in a sequence that determines the gear you are in, so making a switch panel to activate the required solenoids as you push the button for that gear should not be hard either.
The charts I have only show the one way and friction clutch applications for the gears, but I do remember seeing something when at Ford that showed the solenoid applications per gear.
If you set up indicator lights to the solenoid power wires and record them as it shift it and you should be able to figure it out.
You will have to remember to push the correct button as you shift the lever into the desired positions as the trams is a combination of timed electrical and mechanical shifting.
For manual 1 and 2 you get engine braking and the coast clutch is applied in them as well as reverse.
You should be careful as if you move the lever and fail to push the correct button, there might be an incompatibility issue that could cause damage, but I don't know.
I do not envy the shifting you will have to do in the city pushing buttons as you are going up and down through the gears, but at least the lever can stay where it is in "D".
but I am still trying to find some answer to my sons dilemma, I guess I am going to pull it and change the reverse clutches and band plus the plunger. hope it works JNT
Well, some of the efficiency is in having more gears and the lock up converter is not all that it's cracked up to be.
More complication and more possibility for break downs.
But think of this.
2 trucks set up exactly the same except for the trans.
#1 has the C6 with a 1:1 high gear and a 3.00:1 rear end has a 3.00:1 FDR.
#2 has the E4OD with the .72 overdrive and 4.50:1 gears has a 3.24:1 FDR.
The FDR of the C6 is .24:1 higher than the E4OD
Even if the torque converter slips 10% in the C6, take off 10# of the FDR and it's still 14% higher than the E4OD, and that should more than make up for it.
Yes, more gears has more versatility, but at the expense of reliability?
I don't think it is worth it.
BTW, the auto manufacturers only make things more complicated so consumers are less likely to repair it at the local shop or at home.
When they redesigned the C6 into the E4OD, they could have done it easier by simply adding something like a gear vendor to the rear of it.
Give me a C6 and a simple add on OD unit any day.
